993 Turbo Forum 1995-1998
strange clutch feel
Old 08-11-2006, 07:19 PM
sfbanchs
sfbanchs's Avatar
i notice upon hard acceleration when shifting an almost grinding noise comes from the center tunnel. but it deosnt make the noise when driving normally, could this be my clutch, the clutch and all the plates are new so i dont know what it is.
Old 08-11-2006, 07:39 PM
hal m
hal m's Avatar
The problem is a bad acculmulator. I had this exact situation when I bought my car. I finally had the acculmulator changed and everything works the way it is supposed to now.
Old 08-11-2006, 08:57 PM
mleds
mleds's Avatar
Difficult to DIY or not?
Old 08-11-2006, 09:00 PM
hal m
hal m's Avatar
Had it done while doing the clutch
Old 08-11-2006, 10:13 PM
sfbanchs
sfbanchs's Avatar
is cahnging the accumulator a difficult job or pricey?
Old 08-11-2006, 10:52 PM
sfbanchs
sfbanchs's Avatar
what is the consequence of not doing trhe repair right away, keep in mind i just spent a ton of $ replacing all the lifters and doing the front rotors and brakes. I am considering holding out on the accumulator unless your almighty rennlister knowledge advises me otherwise, please advise as soon as possible
Sebastian
Old 08-11-2006, 11:05 PM
911/Q45
911/Q45's Avatar
It is best to change the slave and accumulator at the same time. The parts are about $700 and it's a fairly tough DIY, but doable. Do a search, as Marc in AK did this not too long ago. No real damage will be done if you wait and it won't strand you, but could start leaking hydraulic fluid from the reservior in the trunk right in front of the driver.
Old 08-11-2006, 11:06 PM
Kevin
Kevin's Avatar
Marc in Alaska just did his. He posted pictures of the process..
Old 08-12-2006, 12:39 AM
sfbanchs
sfbanchs's Avatar
the noise comes from the rear of the tunnel close to the engine would this stil lcause leaking in the front?
Old 08-12-2006, 08:55 AM
Porssche4563
Porssche4563's Avatar
How about a squeak when you depress the clutch pedal? My 97 tt has this fault but it goes away after being driven?? Any ideas?
Old 08-12-2006, 12:56 PM
mleds
mleds's Avatar
Why does this cause leaking fluid in the front of the car?
Old 08-12-2006, 02:35 PM
911/Q45
911/Q45's Avatar
You need to do a search and read what has been covered previously. There is a backup reservior in front that is connected to the rear pump by a seal in the slave that fails.
Old 08-13-2006, 01:26 AM
Rob 97 993c2
Rob 97 993c2's Avatar
would the grinding possibly be a worn-out synchro?
Old 08-13-2006, 10:25 AM
LT1
LT1's Avatar
I see this thread popping up lately so I figured I'd update...I replaced the slave and accumulator a year ago and the clutch feels/works perfectly before/after startup even after extended sits (3+ weeks). Costs slave cylinder $688, pressure accumulator $106, Labor $320 (4 hours)
Old 08-13-2006, 12:36 PM
mleds
mleds's Avatar
Very helpful... Thank you.
Quick Reply: strange clutch feel
