Blown Engines?
Originally posted by vrus
- - You can't blow an engine by "over-revving" while accelerating.. That's what the rev-limiter is for. The only way you can blow the engine is by missing a downshift (ie. putting it in 2nd instead of 4th while in 5th).
RL Technical Advisor
Todd:
A flat six IS inherently perfectly balanced as both primary and secondary forces are cancelled very effectively by that layout and firing order.
Victor - very good advice there.
J.Seven - the factory rev limiter is set around 7100 I believe - plus or minus 100. Someone here can post the exact numbers if they want to check their manual.
Originally posted by ZCAT3
911/Q45 - is that straight from the owner's manual? I thought it was higher. I know on my 930 it is over 7000.
Yep - you guys are right - 6720 right from the manual. I was mixing it up with my 930 which is 7000 +/- 200, also right from the manual. That explains why I have hit the limiter on my 993TT but never have hit it on the 930.
No wonder you blew it up
500 miles on engine, not even broken in. Tracking it and overrevving.
Poor engine :-\
Oh well, at least it was driven, but a little early.
Poor engine :-\
