View Poll Results: 993 RS manual steering conversion
Good idea
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
12
41.38%
Bad idea
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
17
58.62%
Voters: 29. You may not vote on this poll
993 (RS) manual steering discussion
However I'm not referring to make a 993 into a '72 s.. that can obviously never happen. Just in terms of that raw feel and connection coming through the steering wheel, that power steering can never fully satisfy.
Cheers!
Here's a few thoughts - had manual steering in mid-year Carrera's (not even 2300 lb early light cars with very narrow tires).
It's 'charming', I liked it, it worked until mid 80's with still manageable front tires around 205, a car well under 3,000 lbs., and the large 'bus' steering wheel. The last point is not to be underestimated.
My 993 is heavier, runs 235's, has a smaller wheel - I can't imagine how that would be a good time, even on track, ditching the PS which is nicely weighted too.
If I had a line on a manual rack for cheap, and wanted to try it with 'free' labor - why not, I suppose. Can always reverse.
YMMV.
Cheers
Matt
YMMV.
Cheers
Matt
As I mentioned to the OP via PM, there's an easy way to find out what a manual steering 993 feels like. Going downhill in a parking garage at low speed, switch the key the accessory position so the engine stops but the steering wheel doesn't lock. Now drive around some turns without power steering. That's what your car will feel like every day with a manual rack. If it's road feel you're after, you're going in the wrong direction -- because you have to muscle the car through every turn, what you actually feel is your shoulder muscles working, not the road. Many years ago I put a manual rack in my 993 and drove it like that until I couldn't take it anymore. It is all downside. But OP, your heart is set on this, so go for it.
Manual steering sucks. I deal with it on my 89
But I think the feel on the 964 and 993 is quite good and it definitely saves your arms big time especially in track or canyon runs.
If weight or parasitic losses are a concern get the cup setup from the 997 or one of those Mercedes a1 pumps.
I may be wrong?
Cheers!
Not a 993, but I have a 964 widebody, 235 section Michelin Pilot Cup 2 front tyres and a manual rack. Recently had it on the scales and it's 1272kg with 1/2 tank of fuel. I run -3.4 camber, and not sure if this has any bearing on steering weight. For me, the steering weight is ok once on the move, can sometimes be a PITA when parking but it's a minor irritation. If you track the car on a circuit with a lot of hairpins you'll certainly feel it the next day. I've never regretted the decision but if I could turn back the clock, I'm not sure I'd do it again purely from a cost/benefit point of view.
Glad to hear there are people who aren't bothered by it.
Cheers!
I think, no one here is driven a original 964RS or 993 Racecar with a Manual rack. It feels so direct and tight to the street thats a really gap.
One of the best changes on a sporty car.
Regards
Regards
You will regret it on a street car with wide tires up front, especially when you're in slow traffic or parking. Better get to the gym now...your arms and shoulders are going to get a work-out!
Technical Guru
It is an absolute joy on the street with 205/55-R17 up front. But if you are trying to win 1st place at your DE by putting on the widest tires possible then this might not be the mod for you.
I know this has been discussed before, but I wanted to ask how it's working out for anyone that has done this conversion to any 993, and ideally below which weight would manual steering be preferred (mostly as dd but also for track)
Would the RS be light enough or does more weight need to be shredded off (if so, where)?
Thanks in advance.
Thanks in advance.
why would you want to remove the power steering
I never really gave much thought to the 993 power steering until I started driving a 964. The 993's steering is quicker and easier, but strangely I prefer the weightier feel of the 964 steering. I simply feel more connected to the road with the manual steering. It's a lot more work in parking lots, but worth the extra effort for the road feel when at speed.
That is correct. A manual rack is MUCH easier to turn the wheel than a de-powered power steering rack. With a deactivated power steering system, when you turn the wheel you're not only feeling resistance from the road/tires, but you're also fighting the hydraulics & PS pump. Ratios are likely higher in a PS car, too, so you'd also be fighting that extra load.
I suspect the same would be true in a 993. It'd be a bear in parking lots, and you wouldn't be able to drive it with one hand on the wheel and the other with a cup of coffee...but I suspect that if you're considering the mod it's likely that you're not looking for a cushy super civilized 993 anyway.
BTW, if anyone happens to have a 993RS manual rack they don't want anymore, I'll be happy to take it off your hands.
