993 Forum 1995-1998
Convertable Top hinge marks-Need feedback
Old May 29, 2017 | 10:17 AM
Rockit's Avatar
Rockit
Default Convertable Top hinge marks-Need feedback
You guys with Cabs...
My top is new Porsche, I've had it for just over a year. I always get deep hinge impressions, 2 on each side on the edge about to the rear of the door glass.
Yesterday I just noticed a small tear starting.
Does your tops also do this? Not the tear but deep hinge marks.
I'm thinking the top was not installed right or the hinges were bent.
Old May 29, 2017 | 12:27 PM
Rockit's Avatar
Rockit
Old May 29, 2017 | 01:31 PM
Holytin's Avatar
Holytin
So that is a new top canvas ay around 1 year of age?? Mine was replaced in 2006 not OEM but GAAH. Looks still fine - no issues. Who installed?
Old May 29, 2017 | 01:39 PM
Disraeli's Avatar
Disraeli
Not sure what is going on there, Rockit. Here are a couple of shots of my now 19 1/2 year old top.
You can see the an impression on the passenger's side because I've been driving around top down this weekend but if I leave it up for a day or two and use some cab conditioner on it it goes away.
File Type: jpg
File Type: jpg
Old May 29, 2017 | 08:45 PM
Holytin's Avatar
Holytin
Those marks look like indentations caused by the pins (left/right) when the canvas does not fold correctly and get's pinched. Happened to me once and I always stop the top 3/4 down to ensure the top is folded correctly. Most likely that's what happened and not hinge marks. See a similar mark on the pictures provided with the previous post, especially on the passenger side.
Old May 29, 2017 | 09:10 PM
Rockit's Avatar
Rockit
Thanks for the help.....I'll try and stop the roof 3/4 and keep it away for the hinges. Sucks..brand new roof and headliner.
Old May 30, 2017 | 12:34 AM
Disraeli's Avatar
Disraeli
Good to know, I'll try it the next couple of times to see what that looks like.
Old May 30, 2017 | 05:30 PM
2RedPorsche's Avatar
2RedPorsche
If these are from the pins as Holytin is suggesting it has nothing to do with hinges.
The pins are nasty big spikes sticking up just waiting for your roof so that they can puncture it, argh!
There is a bar that is pulled back by elastic straps that in turn pulls the canvas back out of the way of the pins. However it doesn't always happen that way due to the loss of elasticity in those straps with time.
It is the bar that Holytin is saying to watch and make sure it's doing its job properly.
I know because I have matching holes through the canvas on both sides of my roof!
Old May 30, 2017 | 06:15 PM
Rockit's Avatar
Rockit
Thanks...did you happen to take any pictures ??? not of the hole but the strape...my roof is new and I guarantee its not there if it not part of the roof.
Old May 30, 2017 | 07:15 PM
e9stibi's Avatar
e9stibi
Root cause are the elastic straps that are broken or do not provide the correct tension to pull the canvas away from the poles while the top closes. I would expect that a professional installer gets this right and than it lasts for more than just 1 year.
Would be interested to see more pics of the strap in several positions of roof opening.
Old May 31, 2017 | 12:55 AM
vincer77's Avatar
vincer77
Another reason why manual operation is my preferred option. If you have to be out of the car to make sure it folds correctly, no reason to use a switch. You can't reach the switch and fold the top properly at the same time.
Old May 31, 2017 | 08:48 AM
Holytin's Avatar
Holytin
Switching to manual is not a valid option for everyone including myself, and won't remedy the situation. Just a "patch" the way I look at it, maybe even less. You still have to get out of the car, manual or automatic, to lay down the top and to make sure everything is where it should be. Another good practice (while you are out sorting everything) is to lay a large towel on the rear window before it is completely folded to prevent a scratched and 'hazy" looking rear window. This way you avoid contact "clear plastic-clear plastic" and your window will look like new even after years of operation. Mine still does after 11 years of operation.
However, best thing to do is to pay attention to detail regardless. Happy hump-day!
Old May 31, 2017 | 09:32 AM
quakerJacket's Avatar
quakerJacket
Any chance someone could post a picture that helps show how to make sure the top is folding properly?
Thanks,
Joe
Old May 31, 2017 | 10:03 AM
Rockit's Avatar
Rockit
Thanks,
Joe
Yes that would be a HUGE help.
Old May 31, 2017 | 05:32 PM
2RedPorsche
It's hard to capture a good pic because everything is black but I've attached the best I could get.
You can see the bracket for the bar (piece with long part number on it) and it's in the correct position. You can see the large pin to the right that will puncture your roof if the bar isn't pushing the roof back. The wavy elastic under the part number on the bracket is the elastic on the passenger side and you have the same on the drivers side. Mine doesn't seem to have much tension to it anymore but lately my roof has been behaving and the bar has been pushing the canvas back.
You can also see a patch that was glued on from the inside by an upolstery shop to strengthen the roof on both sides where it's been punctured.
Hope this helps.
File Type: jpeg
