How does one remove the rear deck emblem
Hi, is there an easy way to get the "Carrera 4" emblem off my rear deck? is it glued on or bolted thru the deck? Any tips will be greatly appreciated. Thx Joe B 96 C4 Cab.
It's glued on. Use a heat gun (hair dryer) to soften the bond, then dental floss worked back & forth to cut through the adhesive backing. Remove the residue w/3M Adhesive Remover. Wash & wax the area.
