993 Forum 1995-1998
Engine oil for my 993
Old Jun 9, 2019 | 01:43 PM
  #76
Don Magee's Avatar
Don Magee
DB, not to hijack this thread, but how do you like the RS clutch and lightened flywheel? Some folks have issues when installed on a 95. I suppose I will have to replace my clutch fairly soon, and I am trying to decide if I should go with a lightweight flywheel or the original.
Old Jun 9, 2019 | 01:48 PM
  #77
pp000830's Avatar
pp000830
Originally Posted by Twilightblue28A
The Porsche Dealer from which I bought my car new only charged $822.75 to change my oil and both filters March 2017! And to pass Pennsylvania State Inspection, emissions exempt, I was charged an additional $339.00 for a back-up bulb and license plate bulb.
This dealer is now my Ex Porsche Dealer.
Apparently, the cost of refreshing those magazines and the K Cup coffee in the tastefully appointed waiting room can really add up fast.
Actually the local dealer has a mechanic with experience with air cooled 911 so I use the dealer, Euroclassics Porsche‎ in Midlothian, VA for service items that I feel independent shops are not likely to do properly, things such as alignments due to the need to set the Kinematic toe, something that most alignment folks admit they can't do because our cars are not even listed in their alignment rack's computer.
In the case of alignments, the end result is very apparent if it is done correctly.
Other work I will give to the dealer if it requires a lift to do and I am unable to get estimates from the local independent shops, usually because they are heavily booked up around here most of the year.
Andy
Old Jun 9, 2019 | 02:00 PM
  #78
myflat6's Avatar
myflat6
Originally Posted by HalfGerman
I was tempted to post a pic of my driveway with a lawnchair. Free wifi and any drink in the fridge!
Old Jun 9, 2019 | 02:50 PM
  #79
Twilightblue28A's Avatar
Twilightblue28A
Andy
Are you referring to Euroclassics Porsche, Chris Stone, Service Manager?
Chris Stone is extremely knowledgeable and very helpful.
Regarding alignment, I didn't know the effect to the driver or my car. I figured that since I drive so few miles I put allignment to the back of the list. I was also told to do the alignment when I replace my clutch.
And yes, I did get a plastic container of water and a Porsche Shopping Bag. The water and the shopping bag were both provided by Main Line Porsche, referred by Chris Stone. Main Line Porsche repaired the underlying problem with my car for $160.00. I removed my car, at Chris Stone's advice, from Porsche of Conshohocken, from which I bought my car new. Porsche of Conshohocken charged over $3200.00 and never repaired the underlying problem and didn't offer a bottle of water. Instead, I got something else....(use your imagination)
Porsche Bottled Water Supplied by Main Line Porsche.
Porsche Shopping Bag, provided by Main Line Porsche.
Chris Stone advised me to get my car out of Porsche of Conshohocken immediately and referred me to Main Line Porsche.
I speak very highly of Chris Stone and Main Line Porsche.
Old Jun 9, 2019 | 03:04 PM
  #80
chsu74's Avatar
chsu74
^ How in the world is clutch replacement and an alignment related?
Old Jun 9, 2019 | 03:27 PM
  #81
Twilightblue28A
[QUOTE=chsu74;15896360]^ How in the world is clutch replacement and an alignment related?[
The lift?? By the way, the $3200.00 charged by Porsche of Conshohocken INCLUDED changing the oil, both filters and the light bulbs. NO WATER!!
Old Jun 9, 2019 | 03:34 PM
  #82
chsu74's Avatar
chsu74
Lift and alignment rack are not the same. BTW, one of my tenants is a Porsche Service Advisor. He can't distinguish either so don't feel bad.
Old Jun 9, 2019 | 03:36 PM
  #83
DB_NC_95C2's Avatar
DB_NC_95C2
I love the quickness with which the engine revs up.
I have had a couple of stalls due to the revs dropping so quickly and the engine management idle control valve not able to compensate quickly enough but once I learned to consistently slow down and leave it in gear until I hit about 1100 RPM before depressing the clutch I’ve been fine, if I need to downshift quickly I can always blip the throttle and raise the revs.
It’s not bad enough to make me want to do the heavier light weight flywheel that I think is made by Steve Weiner (not sure if him, I just saw some posts about it ) but I’m fine the way it is.
Old Jun 10, 2019 | 09:04 AM
  #84
HBi_Auto's Avatar
HBi_Auto
Former Vendor
We highly recommend Motul 300V 15-50 engine oil. Motul 8100 5w-40 also meets the specifications but I like the thicker viscosity for these engines.
Old Jun 10, 2019 | 10:01 AM
  #85
osugasman's Avatar
osugasman
BRAD PENN baby!!! All day long. And do your own oil changes, allows for "bonding time". I've got an oil place near me since we used to have a small airport that has been converted into an awesome park. These guys always have Bran Penn in stock at reasonable prices.
Brian
Old Jun 11, 2019 | 05:07 PM
  #86
skyboy's Avatar
skyboy
Since the suggestion has been made for m1 20/50 vtwin oil, would other 25/50 vtwin oil be recommended? I have ammsoil 20/50 lying around for the other love of my life, so using it for the car and the bike would simplify life a little.
The oil discussions on the Harley boards are equally as entertaining, btw.
Old Feb 1, 2021 | 08:15 PM
  #87
1997hmc993's Avatar
1997hmc993
Originally Posted by AllanH
Personally I use canola but grapeseed has a higher flash point.
I am for the grapeseed oil. That is for my cooking.
