Cost of 993 clutch and flywheel replacement
I'd not do a clutch on a 20ish year old car without dropping and doing the while you're in theres: lifters, PS belt, timing covers, etc. Then there is the crumbling cable on the SAI air pump.....nice electrical hazard.
A friend supplied the timing belts for his Alfa, whoops wrong belts. Result one set of bent valves and no redress. Bite the bullet or risk getting shot.
BTW I wouldn't have trusted those mechanics they were waiters in a local Italian restaurant (not because they were Italian, but that appeared to be the only connection to Alfas)
