993 Forum 1995-1998
Windshield Gasket too small
Old 07-21-2021, 04:21 PM
  #31
alsamrob4
alsamrob4's Avatar
The installer I used is highly recommended by both the local dealer and the indy that services my cars.
Looks like I am using Andy's workaround until the next rock bounces off the windshield, and I fly boomboomthump out for a weekend on the water and glass fitting.
Old 07-21-2021, 04:25 PM
  #32
alsamrob4
alsamrob4's Avatar
INTMD8 you are welcome as well
Old 07-21-2021, 05:10 PM
  #33
boomboomthump
boomboomthump's Avatar
I'm good with that! By that time I will have at least done it twice. I put in new front/rear glass last year and then this year decided to strip the car to bare metal for repaint. Going to reinstall soon.
Old 07-21-2021, 07:36 PM
  #34
aam993
aam993's Avatar
Originally Posted by alsamrob4
The installer said the aftermarket windshields come with a larger gasket, as well as their own channel.
Just wanted to confirm that OEM 993 windshield comes with channel for the gasket attached to the glass from the factory.
Not sure what aftermarket windshields installer is talking about.
Do you have part numbers for the glass and gasket you ordered?
I used 993-541-111-06 Windshield and 993-541-435-01 Windshield Gasket, which worked perfectly on my 993.
Old 07-21-2021, 09:31 PM
  #35
pp000830
pp000830's Avatar
Received 1,464 Likes on 1,032 Posts
Be aware that different part numbers are specified based on the model year of car and if the original glass was updated at some time.
Andy
Old 07-21-2021, 10:04 PM
  #36
boomboomthump
The part number aam993 posted is the one for inner seal that goes on the inside.
The outer seal is: 993-541-925-00, which is the only part number available. It is used for all years.
Old 07-21-2021, 10:09 PM
  #37
aam993
aam993's Avatar
Ah, that's right. I forgot I replaced both gaskets and indeed used "993-541-925-00 Windshield Gasket" as well.
Old 07-22-2021, 10:59 AM
  #38
alsamrob4
alsamrob4's Avatar
That's the part number I have as well.
Played around with some rope caulk, and a 1/4" fits nicely in the gap, and allows the gasket to sit flush on the pillar. Will backfill it a little with roofing caulk. It won't be long before a rock ruins this windshield. If you drive the highways in Mass the stone and gravel symphony off your car is a constant.
Quick Reply: Windshield Gasket too small
