best alignment for autox
gents,
what are the recommended settings for a 993 to be most aggressive for autox. is it true that the more negative camber the better. any other suggestions? does corner balancing make a big difference?
thanks,
boris
thanks,
boris
Boris, don't you have a fair amount of negative camber already? My car felt reborn when I had the PSS-9's installed and went to -1.5 and -2 for camber. I thought that was a reasonable compromise for street and autox/DE. I still have a lot more wear on the outside edges on the MPSC's with pretty even wear on the daily use SO3s. I thought that one of the Tim's was at about -2f/-2.5r.
By the way, I probably will not make it Sunday. Were you going?
Tom,
yes i'm going sunday. are you telling me that you are passing up an opportunity to place 1st for the season? get your priorities straight....
i'm currently running -2.5 f / -3 r camber. My inside edge wears out before the outside edge. so i'm considering trying to get it a bit less agressive...
cheers,
boris
cheers,
boris
