Front ride height diff.
For some reason my driver's side front is 1/4" lower than my passenger side. I've measured both at the control arm and the fender. The spring perch on the passenger side is all the way down, and adjusting the driver side doesn't seem to have any effect.
Are springs typically slightly off like that? Any other ideas?
Also, there is a big difference in ride and handling between gas empty and gas full. I've been told there shouldn't be any real noticeable difference, but there definitely is. My alignment was done (RS specs) at only 1/4 full, so I'm thinking this is the cause. As the suspension compresses, does toe-out and increased camber result?
Thanks!
Thanks!
Troy,
The only way to know is to have a corner balance done at a reputable shop. There is enough tolerance so that 1/4 inch is not outside of reason... but the corner balance is the true check.
As far as empty vs. full differences... I can tell the difference. When on the track 3/4 full is the best for me and my car. I need more weight in the front (and less in the rear) so having some weight due to fuel load works. I haven't addressed less weight in the rear yet.
Re: Front ride height diff.
Cheers, Maurice
I had corner weights checked previously and they would correspond to the driver's side front being low, it was showing a difference just on the outside of the tolerable difference (I forget what that was, 40 or 50 pounds maybe?).
Can you verify which way to screw the perches to alter the height? I thought screwing them upwards would raise the car and vice versa. I do plan on having corner weight and alignment checked after I get the ride height evened out, assuming I can.
As to alignments, I'd heard different opinions on whether to do them with the gas tank full or not, but I am coming to the conclusion that doing it full or 3/4 is better. I had my alignment at 1/4 tank and that's where it does best. When 3/4 or full, the car tends to oversteer and the steering becomes harder (more effort). I suspect it's because as the suspension compresses, the negative camber increases; anyone know whether this is true? Anyone know what happens to toe as suspension compresses?
Thanks for the help!
...as the suspension compresses, the negative camber increases; anyone know whether this is true? Anyone know what happens to toe as suspension compresses?
The car will increase toe setting as the suspension compresses.
Here's my input - had my 993 converted to M030 with Bilstein's and ROW sway bars - then corner balanced and aligned. Had the same issue - front ride height was 1/4 inch different then the other - done with full tank. The driver side was higher. Unless you are an expert and have the tools I'd suggest you leave it to the pro's to get the corner balance, ride height and allignment done.
Ride Height
You live in San Diego, take the car over to the boys at Mind Over Motorsports in Mira Mesa and have them put the car on the scales as well as and measure the ride height. They have set up my car....I am very satisfied as a a number of other San Diego folks.
Thanks Martin, I've been using them regularly for the past several months, I wanted to know what to ask for before I brought it in again. They actually didn't want to do a corner balance because I don't have adjustable shocks all around, just the normal, small adjustment on the M030s, so I was wanting to do that myself (ride height at least) before bringing it in for an alignment check.
