Difference in N1 and N2 ratings??
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Just noticed the front and rear tires are different in regards to a N1 and N2 markings. They are Pirelli Assimetrico's with the front being N1's and rear N2's? What does this N rating mean?
I did look at tirerack's site, but could not find anything.
The rear tires were new april 2001, while the fronts were a bit older as this was the point where I bought the car.
Also curious if there is a compound difference?
Thanks!
Thanks!
I'm speaking for Bridgestone tires, but in their case the N number is a specification from the car maker, Porsche in this case. I talked to a rep at tire rack and he said they don't even know what the exact specification is, Porsche doesn't make the info public.
I'm not sure if Pirelli uses the same kind of system, but it sure sounds like it.
Re: Difference in N1 and N2 ratings??
Tire Rack: Porsche N-Specification Tire Approvals
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
thanks all for the info--guess I didnt spend enough time at tire racks site. I swear I looked!!!
While looking at my car prior to purchase, when told the "rears are new", all I did was verify they were the same brand and type. Never noticed the N1 and N2 markings.... I also noticed these tires have absolutely NO treadwear or temp ratings... I have looked while the wheels were off the car for cleaning etc. Nothing stating specs.... Is this normal for Pirelli?
You must look closer. DOT requires all tire manufacturers to show this information on the sidewall. I have never seen a modern day tire without them. Pirelli's PZero Asimmetrico is 140 - A - A.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Viken, thats exactly what I have always known, but I swear I have examined both the front and rear tires and there is no treadwear/temp info on the inner or outer sidewall of the tire....
Very strange....
Very strange....
