Humming noise coming from passenger side?
Hi guys,
Do you get a slight humming noise from the passenger side.
I am not sure if it is the oil cooler, but it happens when I start the car, it is very slight.
I can only hear it when idling as it gets drowned by the engine when running.
I am not sure if it new, but just noticed in the summer.
-Kadeer
-Kadeer
Kadeer;
I think what you are hearing is the electric fuel pump which is located in a compartment just ahead of the passengers footwell. If you listen close to the ground behind the front right wheel you should confirm the sound.
