993 Forum 1995-1998
Gong keeps going after key off and removed
Old Sep 28, 2016 | 10:35 PM
captain satellite's Avatar
captain satellite
Default Gong keeps going after key off and removed
The "gong" noise to warn you about the key left in the ignition keeps going when the doors are opened even if the key is removed from the ignition.
Did I do something wrong or is this happening to warn of (check engine) codes, etc. Even if not sitting in the car, the gong starts or keeps going. It stops when the door is closed.
Thanks.
Old Sep 28, 2016 | 11:18 PM
squidge's Avatar
squidge
Your parking/headlights are turned off fully?
Old Sep 28, 2016 | 11:36 PM
TMc993's Avatar
TMc993
+1...Also, it will chime if you leave your turn signal stalk in the left or right turn position and remove the key.
Old Sep 29, 2016 | 01:16 AM
captain satellite
Lights off and turn signal stalk in neutral. Still the gong.
Old Sep 29, 2016 | 08:37 AM
pp000830's Avatar
pp000830
Interesting, I have never found my car to make any sounds when the key is left in or the lights are left on when I purchased it. That'a not broken, that's a feature! Years ago I found the feature on the wiring diagram but never found the actual components. I assumed my car simply did not have this feature. In a flash of ADD I even went ahead an added an aftermarket chirping buzzer for this function.
Where is the relay, that in my case is probably non-functional for this, located??
Old Sep 29, 2016 | 08:55 AM
Gbos1's Avatar
Gbos1
Mine makes zero sounds like that.
Old Sep 29, 2016 | 11:30 AM
captain satellite
I used to be able to pull the key out a bit to stop the the gong, if I was just repositioning the car or knew that I'd be right back into into the drivers seat or wanted to sit in the car with the door open. I might just look for the gong fuse and pull it if its isolated.
Somebody must of experienced this before.
Old Sep 29, 2016 | 01:27 PM
davesnothere's Avatar
davesnothere
My first thought is a bad connection and/or dirty contacts to the ignition switch / cylinder, so that there's still continuity to the gong even though the key is removed.
I would look at lubricating / cleaning the ignition switch and see if that helps.
Old Sep 29, 2016 | 02:06 PM
fullbooker's Avatar
fullbooker
My car does the same thing, sometimes. I believe that the problem may be in the immobilizer system, but not sure which component.
When you exit car and try to lock doors with remote, do the door leds just flash? Are you unable to arm immobilizer with remote? Can you lock/unlock doors using switch on console?
Those are the symptions I'm dealing with.
Phil
Old Sep 29, 2016 | 02:13 PM
TMc993's Avatar
TMc993
+1...
My gong sounds when:
  • The key is fully inserted in the ignition and either door is open.
  • The parking lights or headlights switches are in the "on" position (With or without the fog lamp switch on) and either door is open with key not in the ignition.
  • The turn signal stalk is in either the left or right turn position and either door is open with the key not in the ignition.
That said, like davesnothere, I would begin with the ignition switch. Use dry graphite and then turn the key back and forth several times to work it into the pins in the switch. If that doesn't eliminate the problem, then I'd start pulling fuses on the turn signal and parking lights to see if something was going on in one of those circuits. I'm betting it's the ignition switch though.
Old Sep 29, 2016 | 07:00 PM
nine9six's Avatar
nine9six
...My thought as well. I was kinda surprised you're not having an immobilizer issue too; but as previously indicated, the ignition mechanism must be stuck in the "on" position and therefor not enabling the immobilizer to become active. Lucky you!
Old Sep 29, 2016 | 10:25 PM
NoRush993/951's Avatar
NoRush993/951
I had this issue and it was the spring failing in the ignition column. I did a write up on this. Search my posts from two years ago on the ignition column / locking/ alarm issues. More common problem than we give credit to.
Old Sep 29, 2016 | 10:47 PM
NoRush993/951
https://rennlist.com/forums/993-foru...sn-t-work.html
Read this. Might help. The sticking gong was the clue that helped me finally solve other locking issues.
Old Sep 30, 2016 | 03:58 AM
akrca4's Avatar
akrca4
The "gong" relay is behind the fuel gauge (the empty spot). I actually removed mine so I don't hear the gong anymore...
File Type: jpg
Old Oct 3, 2016 | 02:01 PM
pp000830's Avatar
pp000830
Thanks! Looks like a standard VW relay socket.
I like you fix too, I bet the previous owner applied your fix long before I owned the car.
Years ago my dad's 1972 Buick Electra had a door buzzer that wouldn't quit. I applied the 15 year old's fix. I put a screwdriver against it and hit the screwdriver with a hammer. With each strike its buzz became more shrill and emphatic like it was reacting to my killing it. After four or five blows it gave up the ghost! Now that was an odd beast of a car. I used it when it was way past its prime to store my kid's tricycles. When it was very old it tended to eat batteries so I began cutting wires under the dash after cutting six or seven wires the car no longer ran the battery down. Funny thing is I never found anything in the car that seemed to have stopped working for having its wires cut, go figure??
