BilStein B8 + M033 - expert on suspension, help
Yes. In the first and second to last pic, you can see the thds and distance you can lower the car with the existing springs.
Different springs could lower the car further.
Thanks guys!! I think 20mm would be great...will it be safe? I mean, will it get enough thds to be safe on spirited drives?
I think the car is to high...what do you think?
Nice ride height, and very clean car! I've got the same suspension, and I can clearly come down a little more in the front based on your setup. Standard ROW is still pretty high IMHO. My front is already lower than ROW and it still looks too high to me.
MO33's with B8's
MO33's with B8's
As I said in the email I sent you, remove the lower collar and drop it all the way down. You will get this:
Thanks guys!!
Foxman, thanks, your car looks amazing, does it have a front splinter? My thoughts on the 993 is that the front doesn't matches the back in aesthetic terms...but yours look different... The front of your setup seems way to high...if you lower a bit it will stay more balanced.
Skl2, great help from you! Many thanks...being a newby in this mechanic world, can you show me a picture of the "collar" you refer? I don't want to loose anything in translation...
And Skl...that is also an amazing color, what's the reference?
Thanks guys
Thanks guys
How come every time I see a 993 photo shot directly from the side, the front wheels look like they have a ton of toe in. My car looks that way also. I know my toe is slightly out in the front. Do you think its the gap behind the wheel to the rear of the front fender is greater than the distance from the wheel to the bumper? It always trips me out.
