993 Forum 1995-1998
Plastic Engine Cooling Fan
Old May 10, 2016 | 03:32 PM
EMBPilot's Avatar
EMBPilot
Originally Posted by nine9six
I think I'll take a page from the aircraft/aerospace industry and have a fan milled from billet titanium alloy, and be done with it!
sure.
a single blade of a GE90 is roughly $100,000
but that's technically composite, and you guys said that wasnt strong enough anyways...
Old May 10, 2016 | 07:14 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Originally Posted by Quadcammer
is there really a problem here?
The fans hardly ever catastophically fail and tend to show easily seeable issues prior to doing so (cracks at the base of blades). 3hp to cool the motor? I'm fine with that.
you can do whatever you like, but this seems like an awfully big waste of time and money.
Stop by the shop sometime and I'll be happy to show you a bucketful of broken, cracked Mg fans. I see more of them every day as the "fleet" ages & accumulates miles.
Old May 10, 2016 | 07:23 PM
71-3.0-911's Avatar
71-3.0-911
Waiting impatiently for Steve's solution.
Old May 10, 2016 | 08:40 PM
Ivan J's Avatar
Ivan J
Here is a pricey fan alternative:
http://www.5thxs.com/product/cnc-mac...he-fan-milled/
I hope that Steve comes up with something more cost effective....
Old May 10, 2016 | 08:49 PM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by Ivan J
That's tasty! And very impressive CNC work.
Andreas
Old May 10, 2016 | 09:06 PM
nine9six's Avatar
nine9six
Originally Posted by EMBPilot
sure.
Not composite due to long-term durability issues; this one will be the very last fan you'll ever use.
They are indeed composite, and "we guys" didnt make that statement, Steve Weiner did. But if Steve said a composite blade would not withstand the long term durability requirements of a 3.6L Porsche motor, then it must be so.
Not taking anything away from Steve and his extensive Porsche knowledge, but you know as well as I, there are many here to challenge you, if even you suggest such crazy talk!
That being said, I was thinking more along the lines of an environmental turbine fan; but gotta admire the comparison...
So without going so big as a single blade/vane of a GE90 (whatever variant you intended), at our level, you'd still be in the high 10's of K dollars, milling a one off, from Ti alloy billet..
In 1995, the GE90 engine debuted aboard a British Airways 777 airplane along with commercial aviation’s first-ever carbon-fiber composite fan blades. Early GE90 engine models boasted outputs between 74,000 and 94,000 lbs. of thrust, and today it remains the world’s largest turbofan engine.
...and "they said it couldn't be done"
Old May 10, 2016 | 09:24 PM
EMBPilot's Avatar
EMBPilot
I hope Steve can make one like the GE90. complete with the titanium leading edge. I'll buy two and send one to AOW to make a clock out of, then live in my car.
Old May 10, 2016 | 09:32 PM
nine9six's Avatar
nine9six
Nope. There are durability issues with composites...My God man, have you any idea the long term stresses of a 3.6; let alone a turbo!?
I hear the airlines change em out every flight.
No need to live in your car, just take out a 2nd. ☺
Old May 10, 2016 | 09:37 PM
KMASS993's Avatar
KMASS993
Not sure I understand why you wouldn't just buy a new one from Porsche... Really not that expensive.
Old May 10, 2016 | 09:56 PM
AOW162435's Avatar
AOW162435
Seared
Gold.
Andreas
Old May 11, 2016 | 12:02 AM
nine9six's Avatar
nine9six
FROM THE LINK...
Product Description
Do you have a cracked our broken cooling fan on your porsche 993 or 964? The original magnesium fan is prone to hairline cracks and failure. Our fans are fully machined out of billet on high end European 5 Axis cnc machined. Each fan goes through a thorough QC process on a coordinate measuring machine. Only $899.
How about that! Machined out of billet! Billet what? Pound cake?
I wonder if they are aware that a casting can be machined billet? Cast a hunk O' material and machine a part from it. Billet What a load of mktg manure.
Old May 11, 2016 | 01:03 AM
Jlaa's Avatar
Jlaa
sure.
BAHAHAHAHA. But srsly, c'mon guys. We need to up the game. Why rely on dated technology circa 1995? This GE90-inspired engine fan stuff will only nullify all the throttle response savings you got from the lightweight flywheel. The systems are supposed to be a matched set. You can't just run an LTW flywheel and expect to run a heavy GE90-inspired fan.
I mean geez, you might as well pair a set of brand new Monroes with those M033s. Heck, why don't you start using Mobil1 0w-30 just for grins?
You gotta run a lightweight cooling fan GEnx style. It needs to have 18-blade fan with a composite case --- and maybe use Titanium Aluminide.
Old May 11, 2016 | 01:12 AM
EMBPilot's Avatar
EMBPilot
the only thing better than GEnx, would be a RED GEnx.
I bet steve is working on this as we speak.
Old May 11, 2016 | 02:26 AM
bcameron59's Avatar
bcameron59
Maybe it's a chunk of wood!
billet
noun bil·let
Definition of billet
1
a : a chunky piece of wood (as for firewood)
b obsolete : cudgel
2
a : a bar of metal
b : a piece of semifinished iron or steel nearly square in section made by rolling an ingot or bloom
c : a section of nonferrous metal ingot hot-worked by forging, rolling, or extrusion
d : a nonferrous casting suitable for rolling or extrusion
Old May 11, 2016 | 10:02 AM
Quadcammer's Avatar
Quadcammer
And thats fine, but as a whole, all the magnesium fans on all the air cooled 964/993s produced don't seem to be producing rashes of failures. As a diligent owner I take a peek at my fan blades every time the lid is open. The cracking appears to be pretty obvious, but I'm sure occasionally you get one that breaks with no external signs.
I guess its a risk I'm willing to take.
Curious though, will you be making a turbo style fan?
