993 Valet Key??
Recently upon purchasing a '96 993 I was given along with 3 normal alarm/key units a ‘miniature’ key only. By key only I mean that it is not attached to an alarm remote. It was referred to as a "Valet Key".
Any ideas as to what function this key performs, given that it can not operate the alarm/disabler??
While on the subject…. how do you gentlemen handle ‘Yahoo’ valet parking attendants?
Thank you.
Thank you.
Jordan
The "valet key" is simply a regular key shaft w/a miniature plastic cap. It is useless for a valet. I carry it as a spare & keep a copy of the key start sequence in the car in case I ever lose my remote/real key. A good plan - assuming I will be able to follow the sequence!
As to valet parking my 993 - I never have & don't expect to in the future. I've heard too many horror stories. If I must valet park, I drive my wife's car, or slip the attendant a few bucks to either leave my car parked at the drop-off or let me self park it (I can use the exercise).
I have two alarm fobs, two full sized keys with lights, and one "valet" key.
I always assumed that the valet key would not open the glove box but just do the ignition and doors. But I never tried, so I don't know if its a full key.
If you want three all it takes is $$$!
Originally posted by Silver Bullet:
<STRONG>I'm more worried that there's someone out there with a key to my car.
I'll bet it would cost a pretty penny to redo the locks, ignition, and central locking.</STRONG>
My 91 C2 came with three keys-- two standard keys (with light) and a key with a very small plastic cover on the end that you would hold with your fingers. The dealer said that the small key was designed to fit into your wallet, to use if you lose your keys. I seem to recall there being something in the owners' manual to that effect, as well.
how does the sequence work?? when i got my 993 '97, the previous owner gave me 2 "switchblade keys" with the remote immobilizer and 1 thin "valet" key. How do I learn/reset the sequence? Am i missing the 3rd switchblade key??
thanks
=rob
thanks
=rob
Rob
You aren't missiing any keys. A new 993 came w/2 keys w/integrated remote (switchblade) + 1 "flat key" designed for wallet/purse for emergencies. All key shafts are interchangeable so, for example, the flat key could be fitted to an additional remote. All this is explained in the Owner's Manual (p.14-15 in mine).
Also explained in detail in the Manual (p.20 in mine) is the emergency override of the central locking/alarm/immobilizer using an involved, time specific, key in door + key in ignition sequence to enter a 4 digit code unique to each car & disclosed on a wallet card supplied with the car.
It is prudent to keep a copy of the override sequence in the car, together with a spare remote battery. The code should be kept secure, apart from the sequence.
Many owners have converted their switchblades to separate key & remote.
See p-car.com DIY key conversion.
There is no need to reprogram remotes unless a new one is added or there is a malfunction.
I never received the 4 digit code (that Dan speaks of) on a wallet card when i picked the car up - yes, i saw p20 in the manual. Can I reset it and start again? What to do?
Also regarding the remote:
1) what type of battery should i keep in the glove box - "just in case"
2) is there a way to make the car recharge the remote when the key is in the ignition - the new M3 has this - kind of cool.
Rob
<STRONG>I never received the 4 digit code</STRONG>
You can get the code for your car from PCNA or your Porsche dealer.
<STRONG>Can I reset it and start again?</STRONG>
No.
<STRONG>what type of battery should i keep in the glove box</STRONG>
The RadioShack part # is 23-154 for a 2 pack. It is an inexpensive 12v battery. The same battery is used in many garage door remotes - it's a pretty common size (same as #23, 23M, VR22, EL22 - among others).
<STRONG>is there a way to make the car recharge the remote when the key is in the ignition</STRONG>
No.
No.
No.
