Corner Balance
I am replacing my M030 suspension with a stock set up. Stock shocks and struts but will keep the M030 sway bars on the car. This is all thanks to a fellow Rennlister. I love this place.
I know I'll need a four wheel alignment after this is done. But what is a corner balance? I did a search, admittedly quick, and didn't find out what a corner balance is? What is done to the car in performing this process?
AND many of you have experience in replacing your shocks and struts, except you're tring to get CLOSER to the earth . For those of you who didn't DIY this project, would you mind sharing with me what you think this swap out will/should cost? If you're not comfortable publishing what you spent, you could PM me. Or, if this is too personal a question, I understand.
thanks Rennlist
chuck
thanks Rennlist
chuck
Guys, a corner balance and alignment for a suspension should only be around $400 to $500. I have this done at my local shop and they charge about 5 hours labor @$80/hr. If you are paying $1000 it must be a dealer, oooch!
-Chris
Excellent article on Corner Balancing in Chris W.'s post above. Read it through if you really want to know.
I just had my car corner balanced and aligned. I told them in advance, my weight which goes into the driver's seat, the ride height I wanted front and rear and they adjusted the corner weights weights accordingly.
At the conclusion of the job, I have the 60/40 front to rear, and less than a a 50 Lb. cross weight Left Front to Right Rear, Right Front to Left Rear delta.
Chris-great article. Thanks very much.
chuck
chuck
-Chris
Thanks a bunch everybody. Thanks to these posts, I am now a much more informed 'shopper' when I go looking for the tech who will do my work.
If I was younger and cooler, I'd say something like 'Rennlist Rocks'. But I'm not. So I ain't saying it.
Thanks to all.
chuck
Thanks to all.
chuck
If you are putting in stock Monroe Struts and Shocks, there is very little to corner balance. The rear shocksd have no adjustment...they can add some plastic spacers if needed. The front struts have some thread on them so the spring perches can be adjusted a wee bit but not much.
A good alignment is important...done by a shop that doesn't say what? when you mention kinematic toe for the rear. They need a special Porsche tool to set the kinematic toe. Advice: Don't scrimp on the alignment. Best of luck with the car.
Thanks Martin. For my use, I thought I might forego a corner balance. Going to use M030 sway bars with stock springs and struts (factory). I may switch to Bilsteins struts at a later date, keeping the stock springs.
I believe I've found a good aligment shop, good history and customer base, and they have the tools.
I appreciate your answer Martin. Thank you,
chuck
chuck
