parts number
parts number
I am going to install the collarsible oil tube with engine in car, since i need to take out the heat exchanger. i will use the new exhaust M8 nuts but i can't find the part number for below photo studs. Is it possible to take out the old one and replace it when the heat exchanger off ?
thanks for imput, i checked with Pelican it mentioned M8 x 38mm exhausted manifold stud, while the other parts supplier in UK, it mentioned M8 x22mm. which one is correct to go???
