993 Forum 1995-1998
NO START - STUCK on a Highway nr Cincinatti
Old 03-15-2016, 02:45 PM
  #31
TJ993
TJ993's Avatar
Pulled into Park car - Died - No restart since 12 hours ago
Old 03-15-2016, 03:11 PM
  #32
JM993
JM993's Avatar
Per Geo's point, this sounds like a fuel delivery problem. If you can find a suitable container, remove the main fuel line at the engine and place it in a container. See if it fills the container when you turn the key to position 2. My guess is the fuel pump is the issue......
Old 03-15-2016, 03:48 PM
  #33
TJ993
TJ993's Avatar
Default fuel
97 Carrera Coupe not turbo.
I have Half a Tank of Fuel.
wondered about the gas I bought last eve 12 us gallons -
Hope that Is that what u mean by Reservoir ?
How do I get this Fuel out of the car>?
I am getting low on Battery - down to 12.24 in 70 degree or 22 C weather
Where is the fuel pump relay???? or Fuse = Any Pics - should/ could I change this part>?
CAN I UNDO THE Bolts HOLDING the fuel filter - force it through?
TJ
Originally Posted by geolab
ok, problem is 100% fuel
thing to find out, is : if it is a small clog, or mechanical (pump-retaining valve-filter)
How much in reservoir ?
Now you'll need to jump start it , ****
Old 03-15-2016, 03:53 PM
  #34
Leander
Leander's Avatar
time to call for a AAA flat-bed truck?
Old 03-15-2016, 04:05 PM
  #35
Quadcammer
Quadcammer's Avatar
Received 1,371 Likes on 794 Posts
is it cranking slow or normally? What do the volts do while cranking?
Do you hear the fuel pump running?
You could try tapping the fuel pump lightly, but you have to lift the car to get there.
If you have an autozone nearby, you could try to get a fuel pressure gauge, thread it in where the schrader valve is, and see if you get pressure with the key on and while cranking.
Old 03-15-2016, 04:06 PM
  #36
Quadcammer
Quadcammer's Avatar
have you tried push starting?
Old 03-15-2016, 04:14 PM
  #37
Dan V
Dan V's Avatar
I would get a jump-start to rule out a bad battery or connection. I know from experience 993 is very electricity hungry and needs ample voltage to keep the engine running.
Old 03-15-2016, 04:30 PM
  #38
TJ993
TJ993's Avatar
Seems It Cranks NORMAL
But now Voltage is Down
How do u get a Boost - Cal a cab >?
Old 03-15-2016, 04:31 PM
  #39
TJ993
TJ993's Avatar
Askin around But Hotel People I hav asked SEEM to have reluctance
TJ
Old 03-15-2016, 04:32 PM
  #40
TJ993
TJ993's Avatar
No bud = here by my lonesome
No energy for that
Old 03-15-2016, 04:34 PM
  #41
TJ993
TJ993's Avatar
Your knowledge is above mine - car is on the ground so sol >? Ideas?
Where is the fuel pump located ?
I am visual - pic would help, if possible
QUOTE=Quadcammer;13110028]is it cranking slow or normally? What do the volts do while cranking?
If you have an autozone nearby, you could try to get a fuel pressure gauge, thread it in where the schrader valve is, and see if you get pressure with the key on and while cranking.[/QUOTE]
Old 03-15-2016, 04:45 PM
  #42
IXLR8
IXLR8's Avatar
Originally Posted by TJ993
Where is the fuel pump relay???? or Fuse = Any Pics - should/ could I change this part?
The DME relay is what powers the fuel pump. The DME relay is a dual relay.
Located at the bottom left in this photo and has DME Relais molded into the top of the plastic case.
Fuse 26 (15A) feeds the pump.
Old 03-15-2016, 04:53 PM
  #43
IXLR8
IXLR8's Avatar
Fuel pressure regulator vacuum hose connected? And not leaking?
Old 03-15-2016, 05:09 PM
  #44
Leander
Leander's Avatar
Why don't you simply call the mechanic's number from Post #2 and get it taken care of?
Old 03-15-2016, 07:50 PM
  #45
TJ993
TJ993's Avatar
Hi Alex
Thank You for responding!!!!
ok that confirms my thoughts - this is the relay. Thanks.
I have swapped out 3 DME relays - 2 oem. and one aftermarket.
No Go.
Tried boost - No start
Initially thought maybe fuel is entering But No start
Second try - I do not think any fuel got thru whatsoever
Fuse 26
IF I Count correctly from the Bottom Right and then up and then Left across there are 3 - 25 amp fuses, all Yellow
Is this the correct location>?
I pulled all three 25 AMP fuses and there ins No Apparent issue - seems good.
Ironically, there is No spare 25 Amp Fuse in the car
My car is a 97 carrera - c2 to some - Base two Rear wheel drive carrera
Thank you Alex
Quick Reply: NO START - STUCK on a Highway nr Cincinatti
