Surflex or Leatherique long term updates
#31
Joanne at Surflex reached out to me after seeing my order and advised that I only need a pint kit for a 911. Joanne and her husband own the company and I thought that was above and beyond for an owner to reach out and make sure I wasn't buying too much! She said she looks at every order and tries to make sure it makes sense for what the customer is trying to do.
#32
Anybody have tips they'd like to ad about dyeing around non-dye items for example the metal portion on a tequipment shifter or ebrake handle? without getting any on the metal but getting the dye completely all the way to the metal? Does it clean off while wet?
#33
BTW, this stuff also comes in clear. I dyed my shift **** boot. I then put a coat of clear to give it a bit more protection. Still no noticeable wear even after 10 years. The clear came from Leatherique with their steering wheel kit.
#34
Thanks Axl.
Can anyone recommend a specific paint sprayer to purchase for diy and/or a business that does re-dying that they have been 'completely satisfied' with as the saying goes....
apologies to op for thread hijacking.
#35
http://www.harborfreight.com/adjusta...gun-92126.html
There are other sprayers that HF sell that may work better. Chose this one b/c of my small compressor.
I would only use the brush for the first thin coat and into the seams. But you really need a sprayer to get a professional finish. No way around it. Tried it with every type of brush, and nothing worked better than a sprayer for the final coat.
#36
I actually used this cheap $13 sprayer with my tire filling compressor. Thinned the Surflex down with some water. It worked really well!!
#37
http://www.harborfreight.com/3-gal-1...sor-60637.html
Heck...if you live in Dallas and want to borrow my compressor (I have the slightly larger one now), just stop by.
#38
I don't see myself needing a compressor.
Would it work with a basic airbrush kit and using this as an air source?
http://www.michaels.com/badger-prope.../10093744.html
I guess it all depends on how much air you actually need for an application. Any thoughts?
#39
Guys, for $80, you can buy a 3.5 gallon Porter Cable compressor that should work for this project. You can also use it to fill up your tires and blow out your hoses for winter. I love my PC compressor.
#40
