Spoiler bearing grinding again...
I decided to try the silicone nitride (Si3N4) version of the 625-2RS bearing. I have it on order from here because I'm in Canada but you can find the same thing on fleabay etc with free shipping in USA:
https://www.bearingscanada.com/produ...c-5-5x16x5.htm
However I will be storing the car for winter pretty soon, so may not be able to report back until spring. In any case, the real results won't be apparent until after several years of spoiler ups & downs, ie does the grinding eventually return again.
Also, just discovered another option to increase the speed at which the spoiler goes up, which sounds pretty much like the RUF version if I understand it rightly. It's a very simple resistor replacement - see post # 52 in this thread:
https://rennlist.com/forums/964-foru...estions-4.html
Edit: this fix unfortunately doesn't work on my 96 C4's spoiler module. Apparently the older 964 version is required for the resistor mod, but these are hard to find and rather spendy.
Last edited by bcameron59; 06-11-2016 at 06:18 PM. Reason: correction re: spoiler module version
Originally Posted by bcameron59
Maybe, but I have no idea where I would find one.
[/url]
[/url]
FYI, I had never tackled a DIY on my own car ever. But with the write ups and resources provided on Rennlist I have now fixed my horn bracket (no more honking when I apply the breaks!), sourced and ordered replacement blows cabin fans and will now fix the grinding in my spoiler. Exciting times.
Even a nice Oilite bronze bushing, which sweats oil, will eventually break down if left open to the elements.
As others have discussed, I believe a sealed bearing is the answer; and even those will eventually break down as micro particulate, environment, and time take their toll on the rubber seals that protect the bearing. It's longevity we're looking for, right?
I think it's also available on Amazon for $25+Free Shipping
S625-2RS Ceramic Si3N4 Stainless ABEC-5 Sealed Bearing 5x16x5 Bearings https://www.amazon.com/dp/B00MYBXJ4C..._rOfowbM8P116P
