Need help for some P/N (ABS DME cover, plastic straps) PHOTOS
Hello,
I'm trying to figure out in the diagram but can't find the correct P/N for the following:
-ABS DME(or module) plastic cover
-Plastic Straps for wirign harness (could be this 96461250100 Joint Flange ?) They has mutliple holes for different size thickness of the harness.
-Fuse base that goes next to the ABS pump module, it holds two big fuses and the cover says "GM" but one of the tabs is broken and can't slide in the body wall. Can't find any P/N on it.
Thanks for any help!
Excellent! Thanks guys.
Now just need to figure out that portable base of two big fuses witht eh "GM" cover on it. As I said one tab is broken and can slide it on the trunk wall tab anymore
