18" to 17" wheels
18" to 17" wheels
Will overall wheel size change 17" from 18 inch wheels require either a alignment or a ride height adjustment, I am using PSS10
I was thinking that with the right tires they would maintain same height
I will definitely need luck with the wheel search. I want E 88 it seems that BBS is having trouble supplying parts to make wheels. If I had to guess I would say there some business going on behind the scene and somebody or some entity is trying to buy them out or acquire their assets.
Moderator
I've thought about this many times before. The suspension people I've worked with in the past (ie: Musante, Jacobs, AAOC, etc.) have all said "have the wheels / tires you intend to drive with on the car when we align", so I suspect there's a reason. Corner Balancing? So maybe 17 vs 18 doesn't matter, but the alignment can be off if you "change" wheels and / or tires?
(Yeah, throw on an alternate set of wheels that are grossly underinflated, or have a laughably bad wear pattern and you'll slightly change the parameters.)
Moderator
As I suggested, it has nothing to do with 17 vs. 18, rather I think it has to do with the particular weight combination of what you have that can influence something like a corner balance. For example, say you have 50 / 60 lbs total front and rear per wheel / tire. And you change that for 45 / 50 and save 5 lbs up front each and 10 lbs rear. I suppose that would throw things off ever so slightly.
Thus, I've been asked to have the wheels and tires I intend to run on the car for when they do suspension work / alignment. And that's the only thing I can think of...
They're the same circumference as you surmised. Clarification please:
OEM equipment:
205-50-17 = wheel diameter of 25.08"
255-40-17 = wheel diameter of 25.04"
AND
225-40-18 = wheel diameter of 26.08"
265-35-18 = wheel diameter of 25.30"
OEM equipment:
AND
http://www.wheelcalc.com/#.
Or, on the 99%+ of these out there which do not have adjustable stabilizer bar drop links. Amazing how much preload is introduced with the stock components.
