ignition switch replacement : Fail
Today I tried to replace the ignition switch (electrical part) (http://forums.pelicanparts.com/porsc...on-switch.html)
I need to few bandaids on my hand and luckily I don’t have a backache! But i'm very disapointed because I failed. I had access to the switch but wasn’t able to remove the visible screw. And, my god, how do you remove the top screw that you can’t even see?
For once I thought I could do it by myself... but I will need to go to the shop...
