Turn signal issue
Turn signal issue
I've searched and tried all the potential solutions that my feeble brain can understand.
Here's the issue. When I use my left turn signal, the indicator on the dashboard flashes at 2x or 3x the normal speed, indicating that one of my bulbs is not flashing. A quick visual inspection by my twins confirms that the front blinker is not working but the rear is. I try a new bulb - no joy. I try the bulb from the right side cause it is working - no joy. I search RL and check the fuses and even replace them - still no joy.
In a matter of about 3 minutes, I've exhausted all of my DIY capabilities. By the way, the bulb does light up when I turn on the left side parking light. Any clues? Thanks.
The front turn signal bulb has two filaments, one for the park/position light, (5W) and one for the turn signal. (21W) They are connected to separate circuits.
The turn signal circuit to your bulb has somehow been disconnected, I would guess due to corrosion in the bulb holder or a wire problem somewhere. It's probably time for fault finding with a voltmeter.
Cheers,
Tore
Cheers,
Tore
Foxman and stace, thank you for your kind feedback, this is highly appreciated.
Cheers,
Tore
Cheers,
Tore
While we're at it and along with Tore; we might as well add Mr. Verburg, the Foxman, Mr. Weiner, and Overboosted to the list of gentlemen quick to lend their knowledge and support to the Rennlist community! You guys and many others, rock!
Cheers,
Tore
Cheers,
Tore
Thanks for the solid advice. As others have said, we appreciate your contributions!
