Should I replace my spark plug wires?
Brian, just FYI (I'm sure you already know), this set does not come with any clips or other attachment stuff. So it might or might not be a good deal, depending on how much extra work is involved.
Or $260 at AutoZone: http://www.autozone.com/1/products/3...sch-09264.html with coupon code Start20 now.
Wires would be about $270 with 5% off, so depending on shipping looks like autozone or rockauto
Cheers/bc
Your discount code is:
3479321731717305
How to Use Your Discount Code
Enter the code above in the "How Did You Hear About Us?" space on the checkout page (above your payment information). Do not enter any other text in that space or the discount will not apply.
Please note: Discount only valid for orders placed online. Code must be entered before order is submitted.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.
This discount code expires on October 18, 2015 so don't wait!
However, like a bonehead, I pulled all the clips off the old one at once, without matching the new ones, so I had to use IXLR8's measurements (can be found with Search) - thanks Alex!
The beru set I got had all of the fasteners on there. The things that group the wires together as they wind through the engine bay. Also, the wires were numbered just like the genuine wires.
Based on the autozone pic, the bosch wires may not have those things. Not trying to knock the Bosch set, but these differences (if they exist) may matter to some folks.
I did mine recently and spent the bucks on a Beru set. I don't have records of when they were last done and my car is closing in on 90K mi. as stated above the biggest advantage of the beru for me is that the wires are factory numbered. that makes correctly placing them a lot easier. could you pull off an old wire and number the new one accordingly? sure; but it did make it easier. certainly not cheaper...
The clips and numbers would be invaluable to professional mechanics as these would make the job go much faster, while they can still charge by the book rate per job as is the normal practice. The extra cost of the deluxe plug set would be borne by the customer, presumably with a markup. All this is normal and to be expected because these guys have to make a living. If you can't DIY and still want to drive a porsche, it's just the cost of doing business.
It might be worth the extra $$$ for someone who has more money than time... but most of those folks just take their car to the dealer. There are of course exceptions who have vast amounts of disposable cash but DIY as a labour of love - true hardcore enthusiasts and kudos to them!
Many others (myself included) likewise DIY partly as a labour of love, but also at least in part to have more cash for car parts, tuition fees for offspring, dinner out with spouse, etc. Usually they still want top quality parts, but are willing to spend the time to shop around for best pricing, and may trade lower cost for a more challenging installation. Different people make that tradeoff according to what fits them best, and if it's worth a couple hundred bucks to them to not mess around with tracing wires and transferring clips, there's nothing wrong with that.
However, if someone is replacing their their wires to save some $$$, but actually can't figure out how to transfer the clips and trace the wires... maybe they shouldn't be DIY'ing in the first place.
As the old aphorisms go,
Time is money.
Money talks.
Talk is cheap.
Therefore, time is cheap.
Time is money.
Money talks.
Talk is cheap.
Fellas,
I've called sunset and my local dealer about pricing on plug wires. I've been told they only sell the plug wires individually not as a set. Have others experienced the same sort of issues? Where are others buying their Beru wires from?
TIA!
Andy
TIA!
Andy
Stace, I apologize if it came across as insulting; all I meant was to confirm mpruden's suspicion the clips and numbers aren't there, and that it might matter to some (and not so much to others). You might may have missed this in the paragraph just before the one you quoted:
So I did not intend to impugn you or anyone else if your preferred tradeoff is to have clips and numbered wires! You are totally right, that stuff makes the job way easier and if I wasn't Captain Cheapa$$ (as my son calls me), I might have popped,for them myself. But fact is, I'm on a tight budget for auto maintenance and while I won't compromise on doing it right, I do make every penny scream for mercy.
Please note that I'm trying to help people out on the forum by sharing good pricing I've found, passing on discount coupons etc. The aphorisms were just my lame attempt at humour (and I'm not clever enough to have put them together myself, I got that from some comedian's act years ago).
Seriously, my thing isn't to rip people down, so am truly sorry if it came across that way. Please accept my apologies if I offended you.
Next month, a good friend and I will be installing a Clewitt kit on my 993. I'm going to take care of some maintenance while we have things apart, and I'm curious to know if I should replace the spark plug wires. Since it'll be much easier to replace them now than later, I'm curious to know what others on the forum think. My car has 106k on the odometer and still drives like a champ. I don't have any splitting on the boots or wires, and have owned the car for about 7 years. Do others replaced these wires based on mileage, or when they start seeing cracking on the boots?
If you're going to be in there already... (but not sure doing the Clewett is really in that deep. For the wires, the right side is a bear with the clutch vent tube and engine tin issues. Do the plugs when you do the wires for sure, since you will otherwise do those right side bits twice.)
Really the only place you'll see something "bad" is on the lower wires around the lower valve covers, heat exchangers and mufflers. Lots of heat there. At 118kmi, I had several that had split outer casing on the wires. The boots are pretty thick, so you probably won't see any wear on them, but I found a couple that were chaffed/cut when I pulled them all out and looked them over.
I can't say its the wires, but I did plugs, wires, cap, rotor, cleaned injectors and my car runs MUCH better (smoother rev'ing, peppier) now. Peppier as measured by the butt dyno (probably due to better fuel injection spray, not wires, however).
I didn't end up buying beru but Pelican and AutohausAZ sells them and it's probably worth checking on Amazon as well.
It's a rather pricey item, so I'd really only like to replace them if others think it would be a good idea -- if not, I'll save the $450.
TIA!
Andy
TIA!
Andy
