Summer weight reduction project
$10 and a quick trip to your local CAT scale would clear up everything here. I'd be curious if you are anywhere close to your guestimate. Going to Recaros over stock seats might save you an additional 30 lbs or so.
The actual weight savings with Pole Positions will be over 60 lbs assuming I don't install sliders, which I won't.
Thanks!
I am, thanks!
And thanks. I've never driven a 964, but I have spent a fair amount of time driving a 911SC, which was partially my inspiration for the interior changes. I like the simplicity and the more open feel of the older cars.
I am, thanks!
Scott, do you know how much weight you saved going with the Fabspeed setup, and did you have any problems passing CA smog?
nice, that set up looks beautiful.
The headers are 7 lbs lighter without heat exchangers. The cats are 8 lbs lighter. This doesn't include any weight saved by omitting mounts and heat shields. You can also save weight on the mufflers by having them converted by FD Motorsports. I haven't had it smogged lately, but speculate it can pass the sniff test but not visual, so it is a matter of how attentive the smog station is. I was thinking of buying a second place in one of the counties that don't require smog just to avoid the hassle.
Alternatively I still have the original cats and swapping it back in would be pretty easy.
"Have you ever corner-balanced a car? It has nothing at all to do with the total weight of a car, and everything to do with the weight on each corner and equalizing the crossweights. Because the seats are smack in the center of the car, and because both seats weigh the same, they will not affect the corner balance."
Corner weight the car with the driver or an equivalent weight in the driver's seat seems to be the logical thing to do.
I have all the sound insulation out, RS flywheel replacing the dual mass, RS carpet set...and I can tell you my car is noisy. But if noise is of no concern, stay at it!
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I haven't pushed them hard yet, so I can only comment on the steering feel, which is good. They are loud, but since my exhaust is loud too it isn't intrusive. I've only noticed it when I hit irregular pavement, which causes a high ripping sound.
I have all the sound insulation out, RS flywheel replacing the dual mass, RS carpet set...and I can tell you my car is noisy. But if noise is of no concern, stay at it!![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Engine pad and interior sound insulation is out also, though I did leave a modified deck cover and the interior fender covers on to try to mitigate the worst of the engine and road noise. So I doubt the additional noise from a lightweight flywheel will change the formula.
Mine now weighs 9.2 lbs but I felt it was worth it to make the interior a bit more livable, particularly with the engine pad out. Plus it is nearly impossible to make the rear speaker area look nice with carpet IMO.
With the rear parcel removed and the lightweight engine sound pad, the sound coming into the cabin was actually pretty nice.
For looks, I put inch thick foam pad under the RS parcel shelf cover. It looks pretty good.
