Summer weight reduction project
Continuing to reduce weight on the 993, I spent many hours over the last three months doing the following:
All A/C componenents removed, with factory non-A/C parts substituted including the engine bracket and airbox filler plate
All heater components removed
Cruise control components removed, column updated to factory non-CC parts
Windshield and headlight washers deleted
Power mirrors deleted, non power factory parts substituted
Rothsport single belt pulleys installed
Fabspeed headers and sport cats installed
FD Motorsports Fister IIIs installed with black ceramic on mufflers, straps, couplers and tips
Modified Fabspeed airbox cover installed with BMC filter
Clutch vent hose removed and tipronic tray substituted
Wevo blue motor mounts installed
RS carpeting installed
Getty Design fiberglass hood and ducktail with X-faktory mesh grill and Seine Systems struts installed
OZ Alleggerita HLT wheels with Bridgestone Potenza RE-71R tires installed
Oddysey 925 battery and mount installed
I also did a bit of maintenance:
Lifters replaced
MAF sensor replaced
ISV replaced
Chain cover gaskets and new fasteners
Lower bumper repainted
Rear axle boots and inside bearings replaced
New brakes and rotors. Dust shields and sensors deleted.
New 3M fender guards installed
Door strap arrestors replaced
New fan installed
Engine oil change
Transmission oil change
Lots of cosmoline removed - Stoner Tarminator worked best for me.
Many fasteners replaced
Collapsed jack support replaced, door strap repaired
Finally, I changed a couple of items which added weight but I felt were worthwhile nevertheless:
Rennline valve covers
Bergville HID and LEDs
I did most of this myself, exceptions being the welding since I lack the equipment and experience, and the painting of the hood and ducktail for the same reasons. It was a satisfying experience disassembling so many of the car's components, and I have a much better understanding of it as a result.
I haven't weighed the car yet, but I estimate it is under 2700 lbs. I assume some of the mods may have increased HP also, but in any case it is noticeably quicker than stock.
My plans over the next year in no particular order include:
Recaro Pole Position NGs when they become available - another 60+ lbs out.
Install lightweight flywheel and new clutch
Euro front and rear bumpers
Lifters replaced
MAF sensor replaced
ISV replaced
New fan installed
Engine oil change
Interesting project. I think swapping out the seats and adding a bit more retro interior notes will pull the 'look' together a bit more, but you've certainly done a lot of hard work trimming weight. The one mod on your list that I'd question is removing the windshield washers. I use mine too often to let go of that "luxury" option.
I'd love to drive along sometime and see how your slim and svelte 993, compares with my highly optioned fatty 993. I've been contemplating a diet plan for my 993, but I don't want to lose the full-leather interior look.
Great work! Keep us posted on further developments.
I was pretty frustrated when I discovered the Pole Positions weren't available as that was very high on my list for weight reduction, plus as you noted the interior no longer looks right with the factory seats. I was told by a Recaro dealer that it will be another couple of months before they can be ordered.
I considered putting in the RS washers, but in the 9+ years I have owned the car I've never once used them. Also, the new hood doesn't have cutouts for the nozzles, so it was easier just to delete the system.
I would be happy to take you for a spin when I am done.
Sorry to say it, but you're nowhere near the 2700 pound mark, much less under it. The stuff you removed totals around 150 pounds. You may be a little under 3000 lbs. When my car was at its lightest -- including LWF, track seats, carbon hood, lots of stuff deleted, etc -- it was still over 2800. It's not easy making these cars light. Take it to some scales if you're skeptical. Also, there's no HP improvement on what you've done with the intake.
I didn't claim the intake added horsepower, but I do like that it further opens up the engine space. For that matter I'm not sure the exhaust work added horsepower either, although I have seen claims here of gains from similar mods.
I will weight it when I have it corner balanced again but I will wait until the new seats are installed.
what is 'Power mirrors deleted, non power factory parts substituted'?
did you remove the entire front condenser/hvac fan system behind the fuel tank?
did you remove the heater crossover tube above the cats? that thing is about 10lbs!
the hood and decklid look like they fit well.
I've removed a similar list to yours but down to bare metal interior, no passenger seat,
680 battery, same wheels but slicks(28lbs lighter than dot tires) but add 50lb roll bar weight.
last weekend I ran the car down to fumes and rolled into impound for official weight, 2857lbs.
that is with driver so 2685lbs empty.
you might get close to 2700 once you change the stock seats, although I don't know the
weight of recaro pole position seats.
Have you ever corner-balanced a car? It has nothing at all to do with the total weight of a car, and everything to do with the weight on each corner and equalizing the crossweights. Because the seats are smack in the center of the car, and because both seats weigh the same, they will not affect the corner balance.
Yes, all the A/C components are gone.
Yes, all the heater components are gone.
The duck required no trimming. The hood had to be shaved about 1mm on the back left.
I didn't list everything I have done, only the most recent changes. As I said, I estimate I am under 2700 lbs. That is without driver. I will know more certainly after I install the Pole Positions. They are 15.5 lbs each not including mounts. Aluminum mounts are about 9lbs total. I won't be installing sliders.
