Rothsport steering rack bushings
07-16-2015, 05:01 PM
No affiliation here, but a product I had looked for awhile, finally found a manufacturer and installed.
Tightens things up a bit - I have manual steering, a rack brace and GT2 tie rods so your experience may differ.
Seen here:
http://www.rothsport.com/Products/Ch...Rack-Brace.htm
BTW, other Rothsport products I have used - steering wheel hub and crankshaft pulley are first class parts.
07-16-2015, 06:31 PM
Quote:
Originally Posted by
Cupcar
says a lot, already having solid tie rods, manual rack, brace installed and still notice a difference.
good, I need small projects to keep me busy.
07-16-2015, 07:30 PM
k722070
I think one is more likely to notice difference with other rubber and flex out of system. Also tires make a difference. Just my $.02, maybe other way around?
07-16-2015, 11:17 PM
hmm, I'll test your $.02 by trying both cars
one with solid rods and track tires, other with sloppy rubber rods and sloppy street tires.
07-17-2015, 12:17 AM
Put mine in yesterday, went to the track today. Another piece of the puzzle that makes things feel just a bit better.
07-17-2015, 01:03 AM
Had put these in and determined from the "play dough" feel of the original rubber bushings, that these were an obvious improvement.
07-17-2015, 07:56 AM
How's the install? Fairly straight forward? I've heard it can be a pain
07-17-2015, 09:59 AM
Mine were a very straightforward install. That said, I didn't much care about preserving the integrity of the old bushings.
07-17-2015, 10:18 AM
Is this needed for a regular daily driver?
07-17-2015, 10:31 AM
Easy install. Just have to gently wiggle the steering rack to create enough room to get around the corner.
07-17-2015, 12:46 PM
Leander
Just my opinion, but I think all (existing original) rubber bushings should be replaced/upgraded on our cars.
07-17-2015, 12:48 PM
If you race or autocross and every bit of steering feel counts, then it may be worth paying someone to install them.
For a daily driver not worth it.
A great DIY project in any case.
07-17-2015, 12:57 PM
Cupcar
Only took about 15 minutes to replace mine. The original bushes felt like marshmellow Easter bunnies.
07-17-2015, 01:21 PM
Page from factory manual on the installation procedure:
07-31-2015, 11:32 AM
Did y'all reuse the bolts when doing this or purchase new ones?
