Flashing immobilizer light
So I was driving back from work this morning and looked down and realized the immobilizer light was flashing. Drove home, shut the car off, took the key out of the ignition and restarted the car fine. No more flashing light. Any ideas what might be going on here?
Thanks in advance!
Derek
Thanks in advance!
Derek
Did you notice any difficulty in starting the car on the trip where you noticed the flashing light? What is the age and condition of your battery?
I have seen a flashing immobilizer light before on occasions when I've been having problems with the electrical / charging system and I don't get a good, solid start. As you described, the light doesn't flash again once the car is turned off and re-started.
My guess is this is the result of a low-voltage condition at the alarm control module on startup.
This in and of itself shouldn't be an issue, but you may want to look around as to possible issues with your battery / charging system.
Happened when I went a couple weeks without driving. Also noticed a slow start due to low battery. Now that I am driving almost daily, no re-occurrence.
Tip? Check your battery.
Happened to me once or twice, too. Each time it was a real funny start up where the engine just barely caught and chugged for a half second and then smoothed out fine. Restarted and light went out as normal. Not worried about it, has not happened in a long time, but clearly remember it.
RL Technical Advisor
Flashing Immobilizer lights generally mean two things:
1) Low battery voltages (not remote). If your battery is over 4 years old, its suspect. Further, bad battery grounds or an alternator/VR problem will also cause voltage fluctuations.
2) No communication between Immobilizer control unit & DME. This can also mean the Immobilizer control unit has a fault.
When I went to start the cab this morning it would turn over but not start. I noticed that the Immobilizer light on the clock was flashing. I disconnected the battery and put it on a charger for six hours and still a flashing immobilizer light and it wouldn't start. For the heck of it I installed my spare DME relay and the car fired up. So, if anyone ever finds this thread while searching "Flashing Immobilizer Light", check your DME relay too.
-Scott
