Strut tower bar recommendations
I'm in the market for one and have not really seen any conclusive recommendations for one after searching previous posts. So I figured I would drop the question and ask the knowledgable folk on Rennlist for guidance...
TIA
TIA
I have the BK unit. They are about $200 new, or $100 on ebay.
They all do the same thing, so you don't need to spend a ton of money on it. Getting the CF version is going waay overboard, imho.
Addict & Guru
Do a search ("strut bar" or "strut brace") - many prior threads.
BTW, don't overtighten the mounting bolts.
Strut Brace Install
I have the AJ-Usa bar, I'm very happy with it. I believe it is a clone of the Cup car bar. It is very sold and well built, no deflection at all.
As Dan has mentioned, you can watch many of the cheap bars flex if you pull on them, which defeats the purpose.
![](http://boards.rennlist.com/upload/Strutbar.jpg)
Pulling on a strut brace bar would not replicate the forces seen by this device in use. The bar will normally see compression forces that are unlike you would see just pulling on the bar to see if it deflects.
That said, the AJ-USA bar feels rock solid and looks good in my car. Price can be right too. Last xmas they had a special on it for Rennlisters for $133.
Chip
Chip
Chip, I agree that the compression force is different, but since the forces will always have a slight radial component due to the fact that the bar can never be perfectly in line with the force vector, I still think a bar that flexes if you pull on it will provide less value. The actual movement of the towers in relation to each other is maybe a few millimeters or fractions thereof, so even a very minor flex could defeat the purpose. (if any, but that's another post.)
I do agree that the most significant value is ornamental.
