993 Forum 1995-1998
Crossover pipe removal question
Old Jun 3, 2015 | 06:45 AM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by Jarg1
I want to take you up on the offer. PM sent. Thanks.
Response PM sent.
Andreas
Old Jun 3, 2015 | 11:30 AM
nine9six's Avatar
nine9six
Andreas,
Very nice work on the tool...Is this your invention, or did you create it from another tool you've seen? Either way, that seems to be the ticket!
BTW, That's one cleanass motor!
Old Jun 3, 2015 | 11:59 AM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by nine9six
Andreas,
Just a loose & hastily-assembled approximation of the 9548 tool.
Andreas
Old Jun 3, 2015 | 01:04 PM
simpsoap's Avatar
simpsoap
Is the car back together yet?
-Soap
Old Jun 3, 2015 | 01:15 PM
AOW162435's Avatar
AOW162435
Seared
MOTB
Andreas
Old Jun 3, 2015 | 03:20 PM
jstyer's Avatar
jstyer
After fighting the pipe and getting it removed, I drilled out the holes to the heater crossover pipe and replaced them with screw/nut setup. Much easier to take on/off imo.
Old Jun 3, 2015 | 04:28 PM
Mike J's Avatar
Mike J
Nice job - need to build a tool like that next time I need it. I have been using the brake/clutch technique with no issues to date ...
Cheers,
Mike
Old Jun 3, 2015 | 08:28 PM
EDoyle's Avatar
EDoyle
Very impressive engineering Andreas.
Please don't look up the price of the fan hub though...you will find out that the "business end" was almost worth it's weight in gold before surgery!
Old Jun 3, 2015 | 08:34 PM
AOW162435's Avatar
AOW162435
Seared
I probably have a dozen used ones in my shop. Worry not, no new fan hubs were harmed for this shade-tree engineering exercise.
Andreas
Old Jun 7, 2015 | 01:06 PM
Jarg1's Avatar
Jarg1
Thanks to Andreas for lending me the crank pulley tool. Old pulley is off and new Rothsport single pulley is installed.
File Type: jpg
File Type: jpg
Old Jun 7, 2015 | 02:03 PM
EMBPilot's Avatar
EMBPilot
lol DungFab tool FTW. Good work man!
It's as smart as ur mini Phillips anti-drop safety twine.
A work of art here.
Old Jun 7, 2015 | 09:51 PM
AOW162435's Avatar
AOW162435
Seared
Scott,
My pleasure. Hopefully the welds held.
Andreas
Old Jul 6, 2016 | 02:05 PM
Nlu's Avatar
Nlu
Bringing this thread back to topic...
I'm at the same point that Andreas was last year, when he made the original post.
However, the bolts on my car are very tight, and I tried to break one loose last night with a good 5mm hex socket tapped into the bolt head, but still felt like it was slipping (rounding) a bit.
I REALLY don't want to round off the bolt heads in the current state.
My end-goal is to remove the engine carrier. Is it possible to just leave the crossover tube attached, remove the engine mounts, and lower the engine a bit, so I can actually get better access to these two bolts?
Old Jul 6, 2016 | 07:50 PM
XavierLaFlamme's Avatar
XavierLaFlamme
Interesting thread. I gotta take some welding classes. Been putting it off too long.
--Michael
Old Jul 12, 2016 | 08:14 PM
Nlu's Avatar
Nlu
I ended up getting a set of looooong hex sockets with the ball-end, and was able to remove these two bolts without rounding them. When time comes for re-assembly, anti-seize on everything....
