front caliper bolts
How common are failed caliper bolts? Because the new bolts were the wrong length, I didn't replace mine but instead re-used the existing bolts when I did my pads and rotors six months ago.
I have never heard on one failing for street or even light track duty, but I have a limited view. I was told by a mechanic (who is a race mechanic, racing since the 964 days) that the reason was not due to stretch, but the wearing of the coating which is essentially loctite - his recommendation was to reuse the bolts with some Blue loctite ....
Andy
From the Workshop Manual...
Brake caliper to wheel carrier* (Note the asterisk)
Size: M 12 x 1.5
Torque: 85* (63) (Note the asterisk)
* Replace bolts (only on front axle) whenever the screw connection has been undone
As for the reason why; I suspect Andy has the engineering rationale.
Size: M 12 x 1.5
I am aware of that, just curious why. As mentioned above, these bolts should be well within their plastic zone so replacement after a single use due to stretching is unlikely. If it were a fatigue issue, I would expect them to be replaced at a regular service interval. So it seems the best reasoning so far is corrosion or locktite.
When torqued to the specified value a fastener is stretched within its elastic range to maximize clamping force. No one designs a cap screw application where a threaded fastener is torqued to the point where it is stretched beyond their elastic limit resulting in reduced clamping force or worse yet setting the stage for fastener failure.
Andy- are you sure that's accurate? I got into the weeds on this subject a few years ago and found some caliper bolts are in fact TTY (torque to yield). Some head bolts also. This means permanent fastener elongation with specified torque applied. This was application specific. I replaced mine on the boxster as the repair manual instructs.
Having said the above, I found the below that seems to negate all the rules of fasteners as I have known. One being that is a fastener that is torqued into its elastic range and during clamp load cycling it never exits the range it will never exhibit a fatigue related failure. go figure?
http://en.wikipedia.org/wiki/Torque-to-yield_fastener
