Cabin insulation
What can be easily added or done to better soundproof and resist engine cabin heat soak? Any feedback from an install done is greatly appreciated.
Andy
Andy
I found this link while researching an audio install. There is a little chat about sound deadening in the RL link I think.
http://b-quiet.com/
link to thread:
https://rennlist.com/forums/964-foru...nsulation.html
http://b-quiet.com/
link to thread:
I have stripped out the interior (well, still removing glue grrrrrrr.)
I have one of the appbiz Ultimate Sound Pads in the engine bay and will be Installing the B-Quiet in the next week or so, will get back to you.
About 18 years ago I did a body off restoration of a Karmann Ghia. I used Dynamat (spray-on), and was not entirely pleased with the result. I think this had more to do with the spray-on, and that if I used the pads, it would have worked out much better. So not much info for you other than to avoid using the spray-on Dynamat.
Bruce7's writeup; post #17 mentions a 2-2.5dB road noise attenuation though hard to know how how precisely this was measured. This is with "dynamat covering 20% more of the lower door compared to the section where the original strip was located", i believe you can cover quite a bit more ie almost all of the inside of the outer door skin, however thorough cleaning required, and might be a bit tricky to apply pressure to get dynamat to stick in some of the less accessible spots.
https://rennlist.com/forums/993-foru...on-repair.html
I would NOT install it on the door inner skins as was done here, which will limit future access to latch & window hardware:
https://rennlist.com/forums/993-foru...rovements.html
Remember seeing another thread where someone posted that the best sound damping in the rear was the thick mat on top of the rear parcel shelf; others noted that adding dynamat back there had little effect / mixed results.
Don't recall anyone posting info about heat soak / insulating value of any engine bay or rear deck products. FWIW there are some at one of the websites linked in the first post, I leave it to you to sort out marketing hyperbole from reality: http://zeronoise.com/automotive_nois..._materials.htm
