993 Forum 1995-1998
Top End Rebuild on 95 993 in Minnesota
Old 02-02-2015, 12:57 PM
  #46
pp000830
pp000830's Avatar
Received 1,461 Likes on 1,030 Posts
Originally Posted by gandalfthegray.
Hey folks, I just recently got a quote for $7800 to do the top end on my 993. I've been out of the loop for a while, is this fair? I was thinking it was going to be closer to $6k. Anyone have any twin cities shops they recommend I try?
Thanks!
Steve
I think the key to managing cost is to get a labor rate/time and parts cost quote break-out for each aspect of the work. For example removing and reinstalling the engine, removing and disassembling the heads etc. Also if some of the costs are contingent on inspection such as replacement valves they should be broken out as a separate quote up-front so you will not have any surprises and more importantly loose control of the cost of the job once your engine is all in parts on the stand. The key here is to become knowledgeable through the quoting process about the process, labor time and parts cost including any sublet work such as machine work. In this way you will know if you are paying a reasonable cost. Just getting competitive quotes without this detail does not ensure you are getting a good value at a reasonable cost as you may be paying the competitive "its good money if you can get it" pricing. I am not advocating being cheap or eve negotiating rates and prices down I am simply saying you will be happier in the long run if you manage the relationship with the shop and you feel the costs are reasonable. Also any reputable shop will give you a detailed quote as they have to do it anyway to ultimately buy parts for the job and invoice you for the work.
Andy
Old 02-03-2015, 03:24 PM
  #47
gandalfthegray.
gandalfthegray.'s Avatar
Originally Posted by pp000830
So why are you considering having your top end rebuilt? What symptoms are driving this decision?
Also how do you use your car that has resulted in the need for this? I see lots of discussions about top end rebuilds but little on why.
A couple of reasons prompted it. First, the shop that conducted the PPI a while back led me to believe the car needed this service and the second is oil leaking on my garage floor all the time. I figured that winter is the time to put the car down and get things fixed. It may turn out that no top end is necessary.
Old 02-04-2015, 12:40 AM
  #48
pp000830
pp000830's Avatar
This does not sound like the right reasons for a top end rebuild. In most cases oil leaks are a cover, oil line-fitting or one of the oil return tubes on a cylinder. The replacement return tubes snap right in place, and are expanded using o rings without disassembly. The only reason I know of as to why a rebuild is needed is if the car is burning so much oil that it runs badly and is constantly fouling the plugs and causing a CEL light.
I bet your fix is a lot simpler than a top end.
Andy
Old 02-04-2015, 04:29 PM
  #49
gandalfthegray.
Andy
Well, I do hope your right. I think new wheels and suspension mods would be a more fun purchase.
Old 02-17-2015, 06:38 PM
  #50
gandalfthegray.
Default Massive leak down percentages
Well, the engine is coming apart. Cylinder leak down test:
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
On the bright side a thorough inspection of the whole car revealed a torn axle shaft boot and a bad windshield washer pump. These are scheduled to be fixed as well as the engine so when she comes home it will 100%.
Old 02-17-2015, 06:46 PM
  #51
NYC993
NYC993's Avatar
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
Wow. Do the valves close at all on 1-3...
Do you have compression numbers?
Old 02-17-2015, 06:53 PM
  #52
gandalfthegray.
No. No compression numbers. They will be inspecting rings/pistons and rod bearings as well and replacing as needed.
Old 02-17-2015, 08:16 PM
  #53
pegdrag
pegdrag's Avatar
That is a lot of air leaking past those valves!
The compression numbers would be very interesting and helpful. Did they do a compression test?
Old 02-18-2015, 08:01 PM
  #54
pp000830
pp000830's Avatar
Those numbers are so high they seem suspect. The car would barely idle or would the car would seem to have no power or really gross symptoms like massive oil consumption (burning oil) with a OBDC fault code present. Leak down tests seem to be a quagmire from a diagnostic standpoint. My view is to not use them to gauge as a primary reason for engine rebuilding unless some other gross operating problem is apparent.
Andy
Old 02-18-2015, 08:40 PM
  #55
MarkD
MarkD's Avatar
1. 75%
2. 75%
3. 78%
4. 10%
5. 15%
6. 5%
Where is the leakage coming from?
A key piece of the puzzle... I would ask.
This could be rings, exh valves, intake valves... it really is important to know
And will predict exactly what needs to be done
Otherwise this could be a rather expensive endeavor
Old 02-18-2015, 09:05 PM
  #56
gandalfthegray.
This was about 300 miles ago.
http://i856.photobucket.com/albums/ab122/gandalfthegray_1/20140419_163142_zpsc8e45642.mp4
Made 237 at the wheels.
Car runs great, just has some serious oil leaks and some staggering leakdown numbers.
Old 02-18-2015, 11:51 PM
  #57
chsu74
chsu74's Avatar
This was about 300 miles ago. Video Link: http://i856.photobucket.com/albums/ab122/gandalfthegray_1/20140419_163142_zpsc8e45642.mp4 Made 237 at the wheels. Car runs great, just has some serious oil leaks and some staggering leakdown numbers.
Assuming 10% drivetrain loss would give you 263hp. Hard to argue with that number for 95 non varioram engine that is suppose to produce 270 new.
Old 02-20-2015, 11:42 AM
  #58
mjsporsche
mjsporsche's Avatar
This does not sound like a top end issue. More likely than not it is about replacing the typical dried out gaskets.
Now why do so many shops push for a top end rebuild? I think we all know why.
Old 02-20-2015, 12:00 PM
  #59
NYC993
NYC993's Avatar
Did you see his leakdown results above?
Old 02-20-2015, 12:15 PM
  #60
axl911
axl911's Avatar
How are you able to get that much power with those leakdown? It would seem like there is a hole in the engine with that leakdown.
Quick Reply: Top End Rebuild on 95 993 in Minnesota
