Mounting Pedal Set
gohno, Just center the pedals and mark the holes with a pencil (then center punch) before drilling, but make sure to get the bottom hole of the brake and clutch pedal to be as low down as possible on the metal base. I have a racing seat in my car, and I suppose the install would have been much easier with the seat out, however, I'm not sure if the stock seat will present the same problem (this is actually a very easy job, but since I'm old, overweight, inflexible and don't have the dexterity that I used to, it becomes a little bit of a challenge; hopefully, you don't suffer from these afflictions). Also, at first I thought the 4mm drill would be too large, but you need that size hole, otherwise the bolts will not easily align.
Doug
Doug
