993 Forum 1995-1998
Wheel bearing question
Old Jan 21, 2015 | 11:32 AM
WingChun's Avatar
WingChun
Originally Posted by jhg41977
Yes that kit has everything. I was referring to the pelican kit not having the additional parts. The link shows the different kits and notes that the additional parts are needed with the smaller kit.
Where did you buy the kit and how much was it (if you don't mind saying)?
Jim
Pelican website listed as $309. The is known as the P3 kit and has all parts needed.
Old Jan 21, 2015 | 02:40 PM
jhg41977's Avatar
jhg41977
I'm having trouble finding it for some reason. Could you provide a link?
Old Jan 21, 2015 | 05:15 PM
WingChun's Avatar
WingChun
Its the one with Pelican part no. PEL-TOL-SIRB90-P3 ($309)
http://www.pelicanparts.com/catalog/...g15.htm#item72
Stu
Old Jan 22, 2015 | 05:12 AM
CaptainGSR's Avatar
CaptainGSR
I am not sure about the front wheel bearings, but for the rears, this cheap Harbor Freight tool works great!
No need to use a puller for the hub. It is really easy to get it out. Just use a hammer and a socket to knock it out from the inside, then cut the inner bearing sleeve with a dremel.
You can also press the hub back in with the same cheap HF tool.
Here is the tool in action: (again, you don't need the puller, the hub is easy to get out with a hammer)
Old Jan 23, 2015 | 08:00 AM
jhg41977's Avatar
jhg41977
Stu
For some reason that one didn't show up when I searched. Possibly because I imputed the year and model of my car? Thanks!
Jim
