Oil Loss After Top End Rebuild
"Top-end "rebuild" means valves, seats, springs, requisite machining, checking tolerances (with care!!!); depending on how else it's "defined" it also includes re-ringing and, with more enthusiasm, p's and c's. As for bottom end, no self-respecting shop or builder would do a full top end and NOT check the bottom. 911 bottom ends are renown for their strength and longevity, and going 300K on the bottom is not unheard of."
Although some may not include the pistons/cylinders/rings, a good "top end" does
Hey Garth,
Before I check the oil dip stick, I let the oil thermostat open then drive the car some more until the temp gauge gets to the 9 o clock position. Then I leave the car sitting(Running) for a few seconds to check the dip stick. If oil needs to be added, I add a half quart at a time.
I keep mine to bottom to 1/3 up the stick for the same reason - these cars seem to like to consume oil when the tank is full. There is LOTS of oil in the system, so that variance of a litre or less is not a problem.
BTW, "stronger valve guides" is not really the terminology to use, the stock valves are soft and tend to wear/oval easily, so hopefully whatever they put in has better wear characteristics.
Its true though, your consumption rate is too high if the engine is tight - so the oil is going somewhere.
What is your mechanic telling you?
Cheers,
Mike
Cheers,
Mike
Great point. When I tried keeping oil level at top of stick, I was burning a lot of oil. I could smell the burning oil as I drove and when parking the car in the garage.
