Door handle stuck
Door handle stuck
1995 C-2 my door handle; button / latch, just pushed in and did not open the door. Also the button stayed pushed in and does not come out on its own. Before I start blindly dissembling my door, has anyone else had this problem??
My '98 has a trigger, not a button. Sticking is common due to lack of lubrication. I suspect the solution is the same, regardless of the shape of the actuating device.
Search the forum. It is difficult to resolve this by trying to shoot in a quality lubricant (not WD40) from the outside. A lasting fix usually involves removing the door card, removing or loosening the exterior door handle from the inside and thoroughly lubricating the trigger mechanism.
Mine looks to be more than just needing lubricant. I can pull out the Lever/ “trigger” and when I push it back in the door does not unlatch. My first guess would be a clip inside the door has come off, need to do exploratory surgery on the door panel to find out. I did a search and could not find anything on the subject, hoped that someone else had already fixed this problem.
With the lever/trigger pulled, try pushing on the door to try to release the tension on the latch, in an attempt to get the door open.
If not, go have some Thanksgiving turkey, and wait for the tryptophan to kick in and enjoy your nap.
Happy Thanksgiving!
Happy Thanksgiving!
it's a bit of a pain to get the handle off... but cleaning and re-lubing the mechanism inside is the solution. The little plastic gismo that covers the inside of the door latch is a pain to get back in the right location... I hate that little sucker.
Good time to replace the exterior door handle gaskets if yours are worn.
Don't forget to remove the little black screw inside the door pocket that attaches the armrest to the door card. This is a super weak area and if you forget it and yank on the armrest... it will crack.
OK, a few hours and all is now well again, actually better than ever, silky smooth operation. The trigger plunger was completely jammed stuck (cold and muck) cleaned with degreaser and relubed. The other side will get the same treatment next week as its no where as smooth as the newly lubed one!
For me the problem was the end of the lever you open the door with broke off. Waiting for replacement part, “Insert without lock cylinder” now I have to learn how to remove my current lock assembly and install it in the new Insert
Simple enough, remove the handle from the car, unscrew the screw at the end of the barrel, carefully remove and replace in the new lock. (make sure you dont drop any pins out of the barrel)
