Lockheed DOT 5 fluid
I just flushed my brake fluid and clutch on my 993 C2 1995.
Replaced it with Lockheed DOT 5 brake fluid!!
Is it OK?
Brake fluid has probably never been changed for the past 8 years!!! removed tons of sludge from the fluid box!!!
Is it OK?
Addict & Guru
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Georges Rebeiz:
<strong>I just flushed my brake fluid and clutch on my 993 C2 1995.
Is it OK?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I assume you mean Lockheed DOT 5.1, a non-silicon brake fluid. If so, it's fine, but IMO needlessly expensive for the application. I believe ATE 200 (or Blue) has better specs at a lower price.
DOT 5 silicon fluid can cause damage to the brake system & should not be used in a 993 (or any other street car).
