Ok not sure if anyone has had this problem
The nut on the bottom just spins??
It looks like the whole inside is spinning.
Is there a way to remove it.
Can i open up the top of the mount and some how
Hold the bolt??
Any advice.
Thanks.
The nut spins, most likely due to the upper 17mm square flange not being captured by the engine carrier .... did this back in '08 ...R&R of broken motor mount
Ya that's what was happening
Used electric impact gun and they came
Off.
Passenger side was toast I guess that's why the
Exhaust was a inch lower on that side.
Thanks.
