AutoSharp Pen
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
A few months back there was some discussion about the AutoSharp Pen by AutoVisuals, who's also a "Rennlist" sponsor. You may recall these little touch-up pens are matched to the paint code of your car. Yesterday, I was touching-up some little chips on the lower front valance and I noticed that when I went to push the point down to refresh the tip with paint, the tip just gushed paint. Anyway, I shot 'em an email and guess what? A new pen is on it's way 2day air, no charge!!
Not affiliated......just pleased
Steve,
Do you use Langka afterwards to clean-up any excess?
I don't have the Autovisuals pen but the other kind (can't remember the brand right now but same concept). I wasn't too satisfied with the color match, even after the paint dried. I know use the factory touch-up paint that has a little more gloss to it. Problem is, I need to use Langka to clean-up and the abrasive properties of Langka appears to remove some of the gloss from the factory touch-up paint.
Rezal-
Sometimes I do.......It depends on the chip. I've really been pleased using a combination of the pen, factory TU paint with a fine artist brush, tooth pick, match stick then Langka. I've had very good luck.....it just takes some time and usually I let the paint dry 30% or so longer than the Langka instructions state. The paint pen from AutoVisuals appears to match perfectly. From past threads I understand that metallic paints are a little more difficult to match.
Cheers
Cheers
