Alternator shim photos...
So I switch out my supercups and now hear a slight whistle coming form the alternator. I want to get rid of it,it's annoying.....
Any more pics about - I have more shims than what's shown...
edit: every car is different, and number of shims vary..smh...great... and I guess the pix below is of the updated pulley...
You might replace those 3 bolts on the right with better/harder M8 bolts so you can't strip the Allen heads, especially if they are already buggered up. Also, some light anti-seize will help the next dis-assembly.
im having the same issue, i changed my hub out to an rs hub... and supercups.
im gonna look into it but it might be that my rs hub bolts are not tight enough or the belt is not tight enough.
to get the belts off the assembly the easiest way to get all the belts, especially the ac compressor belt on is to remove the assembly as a whole. and to remove the alternator for a RS hub.
Yes that's the updated pulley. If this is your existing setup that has worked, I wouldn't change the number of shims unless the belts appear way to tight or loose. I've been doing that for a while...if it ain't broke, don' t fix it. YMMV of course.
That photo was another listers setup..
I think he knows that... To tight on the belt may produce whine (not wine)...I think he was trying to reduce the whine he is hearing
Looks like he was actually too loose and making whine. Too bad 993s make whine, not wine...
