Camber plates/top mounts for Bilstein PSS10
I was wondering if there would be such a thing, a quality made set of top mounts would fit PSS10's on my car for the fronts? There are a few different brands out there, but none specifies they fit a PSS10 kit. For instance, Rennline comes to mind. Or this kit needs a specific set of top mounts/camber plates.
Please advice and educate me on this, I haven't done this modification before, I'd like to get more negative camber than -1.60 for the fronts. Has anybody purchased a set and got them fit on a 993 fronts and have no issues?
There are several options out there including the Rennline product.
http://www.stomskiracing.com/products.php?id=57
http://www.fvd.de/us/en/Porsche-0/-/...front_1pc.html
http://www.stableenergies.com/C2_C4_...P-964-014-SET/
http://www.patrickmotorsports.com/pa...93-343-002-k1/
I use ERP/Weltmeister camber plates with my PSS10s. Have front camber set at -2.5. Probably close to the max negative camber as the outside adjustment bolt is right up against the shock tower on the one side even though there is more room for adjustment on the plate itself.
http://www.automotion.com/weltmeiste...0-porsche.html
