Notchy clutch pedal - so soon?
Replaced my clutch with RS LWF, new slave, line, the whole kit - all within 7,500 miles.
Worked perfectly, butter smooth.
Recently a notchy pedal has returned - you can literally hear a spring-like sound when depressing it. Defective slave?
I will bleed again and see if it improves, but disappointed to have this issue so soon with nearly new parts.
Any other thoughts on how to trouble-shoot?
Best,
Matt
Best,
Matt
It might be your clutch pedal 'kinematic' lever within the pedal box. It's been updated to a -03 part and has a greenish coating to distinguish it as the newer part.
Failure mode is when it hangs up on the return or release. Jackals forge (website) has a nice pictorial on a DIY replacement.
You didn't mention if you replaced your master cylinder as part of the whole kit. I found this thread to be useful. It also mentions the updated lever but I thought that was more of a hanging pedal solution than notchiness. Also do you plan to bleed with the power bleeder wet? Otherwise the clutch system sucks air quickly, right? Seems to get a good flush it would be easier to just use the motive bleeder wet on this one but would be interested to hear other opinions.
https://rennlist.com/forums/993-foru...-bleeding.html
