Hi All,
Was looking through some old receipts from the dealer service records I have in the porsche folder. I noticed that the dealer left a recommendation for me to get the A/C resistor replaced at a cost of $455 installed.
I have a few questions??
1.) What does the A/C resistor do?
2.) Is this just a relay or switch that I can replace in the fuse panel?
3.) what would happen to let someone know that the A/C resistor is not working properly?
4.) what is the worst thing that could happen if it isn't replaced?
I tried to do a search on this but after reading a few posts I think I am even more confused than when I started.
Hi All,
Thanks,
Ryan
I'll give this a shot. Confident that others will add corrections if needed.
1. The AC resistor is what gives your AC fan its lower speed operation.
2. The resistor is mounted atop the AC cooler in the left front fender. It is DIY'able, but you will get your hands dirty.
3. Not easy to tell in normal usage if it is not working. I performed a test to verify that my AC resistor was not working.
4. The fan speed is driven by a thermostat or temperature sensor. When the low speed fan does not work, the AC
gets hotter before the high speed fan kicks in. Your AC parts get hotter for a longer period of time and they are not likely to last as long.
Thanks,
I'll get this replaced before I start using the A/C this year.
I wasn't sure how important this was to normal operation of the car. Of course the dealership fails to answer these questions and made me feel as if I didn't replace it the world would end.
I'll have my independent mechanic do this at the annual service this year.
You should do the oil cooler resistor at the same time. It is essentially the same part and if the A/C one is bad then the oil cooler is likely just as corroded. When I took mine off with 50k it came off in two pieces. FYI it involves removing the bumper I believe.
I did mine a couple months ago, no need to remove the whole bumper. Took about an hour each side, parts are about $80 to $90 per resistor for OE. Or you can build a much better resistor that is cheaper and will last longer but is not OE. Follow this link for that DIY.
Your a/c will achieve colder output with a new resistor. You might think your a/c is ok, but it will be colder with the new part. It does make a noticeable difference.
$54 per resistor from sunset
Pelican is $86...what a rip off
