Roller, Fan Belt Sensor
sunset has never ever been difficult to get a hold of. ive emailed them, had the part out the same day and to my door in 3 days from across the country...
thats cause you got ripped off. the sensor is $70 and the belt is around $30, with about an hour or so of DIY time, prob a little less...
But thanks for the comments...
I'd recommend saving your old one for parts. I replaced mine about a year ago, due to a bad switch. The new one failed last week - the plastic wheel was gone, leaving only the metal center. I was able to open the old part and use the wheel/lever/spring from it in the newer one. It's been working fine.
Good to know. Same thing happened to me. The new roller lasted about 2 weeks, then the wheel was gone. Not sure if its a crappy part or what. I was on a road trip and didn't want the arm and metal bit rubbing the belt so I removed the whole thing. I'll try your trick today! thx
