993 Forum 1995-1998
993 clock spring removal
Old Feb 17, 2014 | 10:12 PM
jlenze's Avatar
jlenze
Default 993 clock spring removal
I have removed the steering wheel air bag after discharging and steering shroud and was hopeful to see the connections for the back of the clock spring But NOOO!!! How do I access the connections so I can replace the clock spring
Thanks in advance Jack
Old Feb 18, 2014 | 12:20 AM
phoneyman's Avatar
phoneyman
Assuming nothing has been touched since the factory, you either need to get up under the knee bolster and cut the tape that holds the extra wiring from the clock spring to the module its connected to in order to get enough slack to pull the connectors through the steering shroud, or you will need to drop the entire lower dash to access the connectors.
Old Feb 18, 2014 | 12:27 AM
Roverdoc's Avatar
Roverdoc
Just went through this. Reaching hand in from under dash...it can be done but it is definitely not easy, i had to cut to factory zip ties to gain the slack as the new part is a 996 number with shorter wiring.
Old Feb 18, 2014 | 05:07 AM
jlenze's Avatar
jlenze
Thanks for the response. I was out there at 4:00 am looking at the situation. I don't see how to get in there. Should I remove anything to open things up or am I not seeing where it plugs in yet?
Old Feb 18, 2014 | 11:27 AM
phoneyman's Avatar
phoneyman
Try some searching
https://rennlist.com/forums/993-foru...ng-photos.html
Old Feb 18, 2014 | 11:05 PM
esses's Avatar
esses
what is a clock spring and why does it need to be changed?
Old Feb 19, 2014 | 02:25 AM
phoneyman's Avatar
phoneyman
the clock spring sits between the console and steering wheel. It connects the electronic parts of the wheel to the car and allows it to rotate while still keep the electrical connections, like a bicycle gyro. It gets removed/added back switching between a race wheel with no airbag to an OEM one.
