993 at fat camp
Nice work on the mods!
Please give us a pic of the center-bar-removed-grill. I've been wondering what it would look like and haven't tried to photoshop it (yet). I wish the cutout were a bit more oval-y.
New perforated leather headlinder, which means all the glass is coming out. I'm getting a new front screen since it's pitted really badly.
Heigo 993 RS bolt-in roll bar is ordered. The DAS bar worked fine but it blocks quite a bit of the rear view.
Bill Verburg has the horizontal bar deleted on his car. You can check out his pictures. I think Don Plumley has his blacked out.
FYI, the duck tail was test fitted and definitely needs removal of one of the struts, unless I want to use it as an air brake
Thinking about just putting in an prop rod, and put some speed holes in the hinges.
Speaking of which, what have people used for insulation material in the roof? I used thin vinyl/foam for under the carpet. Wonder if I should just use the same thing. Is the 3M adhesive going to hold up with the metal getting hot under the sun?
![](https://forums.pelicanparts.com/uploads22/1_14_13__+0191392327489.jpg)
![](https://forums.pelicanparts.com/uploads22/1+4+13+1411392327502.jpg)
Who you getting to install the front screen?
