Fob upgrade
Hi all,
I have a key fob key conversion now and would like to buy another. I noticed Suncoast sells them but for 1995's only? I have a '96... Any idea what I should do? Or where to get it?
Please help and thanks!
Coop
Coop
Coop,
Not sure if there is a difference between the '95 and '96-97 if you are doing just the conversion - using your own electronics (i.e. the conversion).
I purchased the following parts from sunset to do mine.
944-538-041-00 Lighted Key
993-618-959-12 Hand Remote FOB (Shell only)
After ordering the parts I saw this thread
It would have saved me some money. If I did it again, I think I would have gotten a blank key as well and have it cut at the local hardware store as busting (I believe it's the only way to get the key out) up my older switch blade key in a vice kinda bugged me.
Since I have the '97, I really don't need the lighted key but kind of liked the idea. It's got a weird battery in it so replacement of the battery might be difficult. But only a problem if you use the light a lot I suspect.
Hope that helps...
Johnny
Hope that helps...
Johnny
Hi Johnny,
I took the electronics out from the old switchbalde and put them into a new fob a few years ago. Now I would like to have another fob, so I will need the parts you listed above, plus a new electronic keyboard... Not sure where to get that... Did you get yours from a dealer or?
Thank you!
Thank you!
